586,308 active members*
3,482 visitors online*
Results 1 to 6 of 6
    Feb 2010
    32
    Hiwin LG20 grease
    What grease/lube would you recommend fort LG20's on a vertical Z? I'm in the US and machine wood, MDF so oil dripping would be a big proglem.
    Thank you,
    dan
    Feb 2010
    32
    Re: Hiwin LG20 grease
    Anyone? I did find my small Powermatic grease gun that I "think" will fit the Hiwin zerks.
    Thank you,
    dan
    Mobilux EP1
    Feb 2010
    32
    Mobilux EP1
    I hadn't heard of Mobilux but I will give it a try.
    Thank you
    Aug 2014
    125
    Quote Originally Posted by dan j View Post
    Thank you
    Most Hiwin rails are lubed with white lithium grease, initially - but I don't know what they use inside the bearing itself.
    https://www.hiwin.com/pdf/lubricating_instructions.pdf
    You can use anything that isn't moly or graphite. They bung up the tiny balls and stuff the bearing.
    I wipe down with lithium, but if you are going to use the nipple, lithium is probably not the stuff for a grease gun.
    Mobilux is good for woodworking environments - it doesn't allow the dust to migrate too much.
    Feb 2010
    32
    Quote Originally Posted by ledaero View Post
    In case it helps anyone in the future, I bought the Mobilux but was still having a lot of trouble feeding the Hiwin's zerks. I bought the clamp-on quick-release connector and now have zero leaks.
    Anyone have an idea on how many pumps to give the LG20's? I don't see an overfill port.
    Thank you,
    dan
  1. Hiwin HG20 grease fittings???
    By moparx12 in forum Linear and Rotary Motion
    Last Post: 04-03-2018, 12:25 PM
  2. HIWIN Block grease nipple lateral
    By alirezaemami in forum Linear and Rotary Motion
    Last Post: 05-06-2015, 04:59 PM
  3. Hiwin Rails/Grease fittings/lubrication?
    By CyborgCNC in forum Linear and Rotary Motion
    Last Post: 09-04-2009, 07:51 AM
  4. Grease fittings for Hiwin 20mm blocks
    By escott76 in forum Linear and Rotary Motion
    Last Post: 04-30-2009, 03:40 AM
