586,110 active members*
3,150 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach TTS toolholder library for Fusion 360
Results 1 to 11 of 11
    Mar 2020
    218
    I'm not sure if anyone else has done this but my searches have turned up empty. Many of you may have noticed that along with the new tool library in Fusion 360, all the previously built in tormach tool holders are gone. Not to mention the list was somewhat incomplete anyway. I wasn't overly concerned about it until recently due to an embarrassing number of crashes that could have all been prevented if I had tool holders selected when simulating my tool paths. I finally decided to eat the time and make a new library for myself. I have attached said library here in case anyone else has need of it. Included are the 1/4 and 3/8 set screw, er20 and 32 collet, slitting saw arbor, 1/4, 3/8, and 1/2" keyed chucks with JT taper bases, tension/compression head with generic quick change chuck installed, and a super generic tts base that can be used for things like a superfly or shearhog. These are a bit simplified but should all be accurate to within a couple thou anywhere it matters.
    Attached Files Attached Files
    Jul 2011
    400
    Re: Tormach TTS toolholder library for Fusion 360
    You need to import the library back into fusion 360.
    Directions here.
    https://knowledge.autodesk.com/suppo...usion-360.html
    Mar 2020
    218
    If you're referring to the sample tormach libraries listed for 1100 and 440/770 starter, those do seem to contain the tool holders that used to be available directly in fusion (knowing that would have saved me some time) but only the 1/2 and 3/8 set screw, jt1 drill, and er20 collet holders. I've added the two larger drill chucks, the er32 collet, the 1/4" set screw, the tension/compression quick change tapping head, a somewhat generic 1" slitting saw arbor, and a general purpose TTS base for use in creating any additional custom tooling.
    Jul 2011
    400
    Quote Originally Posted by soofle616 View Post
    I see what you mean. Its a bit sparse. I did not really use the original Tormach tool library so I was not sure how much was in it. I do use the TTS but not on a Tormach. Someone out there must have a more complete library to download.
    Mar 2020
    218
    Quote Originally Posted by upnorth View Post
    Someone does. It's attached to the first post
    Jul 2011
    400
    Ok there it is! I tend to go in here first think in the morning before I have had my first coffee. I'll download it and have a look.
    Mar 2019
    34
    Thanks! Nice work
    Oct 2020
    I haven't used Fusion for over a year and recently got back on to discover the change in tool library and setup. Thank you for added this file to upload for the holders. How or were do you input the total length of the tool and holder? The way Fusion was before the change the overall length included the holder also. Now it seems the overall length is the total length of your tool cutter? Thanks again!
    Mar 2020
    218
    Custom tool holders can be defined through the tool library. You create a new tool but in the first window where you are asked what type of tool to create you select holder. From there you don't enter the overall length as a direct input, instead each section of the tool holder as defined but an upper diameter, lower diameter, and length gets defined. Stack up enough of these cylinder or cone primitives and you have a new holder.
    Oct 2011
    134
    Thanks for this upload soofle616, just jumped into CAM after about 8 months away - with my tool library gone awol through what I think was one of the updates .... this has saved me a heap of time.
    Aug 2020
    4
    Thank you for taking the time to post this. It's much appreciated.
  1. Replies: 4
    Last Post: 06-07-2020, 04:45 AM
  2. Has anyone done 4th axis on Tormach and Fusion
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 12-05-2016, 11:04 PM
  3. Need some quick help, Fusion 360 CAM and the Tormach Lathe
    By David Bord in forum Tormach Slant Lathe
    Last Post: 03-17-2016, 05:50 PM
  4. Tool Library Tips/Tricks Fusion 360
    By tbev in forum Autodesk CAM
    Last Post: 12-18-2015, 04:11 PM
  5. Tormach Post and Fusion 360
    By grimms3 in forum Tormach Personal CNC Mill
    Last Post: 10-20-2015, 04:58 AM
