586,119 active members*
3,607 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Avid CNC Pro or Benchtop Pro vas alternatives
Results 1 to 10 of 10
    Aug 2019
    4
    I want to buy a CNC router for hobby use in my garage and researching my options. Considering Avid machines like Benchtop Pro 2x3 or Pro 4x2, Camaster Stinger I 2x3 or 2x4 or Shopsabre 23. Avid CNC routers with their plug and play electronic kits (Nema 34 and spindle) + switches and such for complete system, brings the price to the level of Camaster and Shopsabre machines. what could be better?
    I want to work with wood and aluminum (thick plates) and other various materials. I know routers are not that precise as CNC milling machines, but I want to get maximum precision for such machines. Besides I will upgrade to 4th (rotary) axes in future as time and money allow.
    Turnkey machines (Camaster and Shopsabre) come ready to use even with preconfigured PC and software, but no spindle, just with 3HP routers at that level of price. It is not clear if it easy to upgrade to a spindle in future without buying one from manufacturer, as they are QUITE expensive. Thinking, to add one of better chinese made spindle with good VFD, but do not know if it's possible to configure WinCNC software to control it. I do not worry about mechanical mounting. The same WInCNC question about adding shop made rotary attachment. With Avid CNCs it looks more open to those concerns, as you have to buy all software like G-Code processor with smooth-stepper card and CAM (which is included in other packages) on you own (and pay more). Avid requires assembly and careful tuning, which is time consuming and better done with good measurement equipment to achieve maximum precision.
    What are you opinions and advises would be? Is AVID CNC still better option?
    Aug 2019
    4
    Re: Avid CNC Pro or Benchtop Pro vas alternatives
    It seems that buying Avid CNC Machine kit + spindle and nema 23/34 plug and play kits does not make whole machine. I will need to buys extras like homing sensors, spindle mounting plate, may be something else, right?
    Quote Originally Posted by umnik View Post
    Give us a call, our staff will gladly answer all your concerns -- you can also contact Brandon (ShopSabre Sales Manager) and he will happily discuss as well.
    We are here all day and want to help you with your decision.
    ShopSabre offers many advantages when working with various materials including Aluminum routing.
    Oct 2020
    5
    I have been researching similar machines. Couple things I have found comparing Shop Sabre 23 to the AVID pro 2x4
    Shop Sabre:
    Cost $9200 includes machine, shipping, and a set of bits. (Does not include base or dust collection or other misc.) Enough to start cutting.
    Complete machine ready to go without assy. Actually tested before machine is shipped.
    Shop Sabre needs to be purchased with the spindle up front +$3700... cannot upgrade later if start with a router as needs different controller and wiring.
    Shop Sabre spindle option is more expensive ($3700 vs $1700 but not sure on spindle quality)
    From everything I have read and heard there service and support is the best
    Avid CNC
    Cost $7500, includes machine with all similar accessories to Shop Sabre, router, set of bits, computer, shipping. (Does not include base or dust collection or other misc.)
    Can be upgraded to larger machine
    Will need assembly
    Can be upgraded to spindle without changing controller
    3hp spindle upgrade $1700 (not sure on how quality of spindles compare)
    Question I still have is comparing the 3D carving capability of the 2. The Shop Sabre is ball screw and the Avid is rack/pinion. Does anyone have experience with detailed carving on the Avid pro rack and pinion machines?
    This is not entirely true statement, to clear up some confusion you absolutely can upgrade to the Spindle in the field on any ShopSabre Router - this is an advertised benefit to owning ShopSabre Technology.
    You can start with a scaled budget and grow as you need with most options -- the Spindle package is a common upgrade in the field because accessories are expandable quality is not.
    The ShopSabre Spindle package is the Mitsubishi VFD and HSD Italian Electric Cooled Spindles - they are the top rated packages on the market.
    Again we are happy to discuss with you as well, you can call our team or reach out to Brandon directly as well (Sales Manager)
    Thank you!
    - The ShopSabre Team
    Quote Originally Posted by Kspe View Post
    Shop Sabre:
    Avid CNC
    Will need assembly
    Oct 2020
    5
    Quote Originally Posted by ShopSabre View Post
    Thank you!
    Thanks for clarification... apologize for mis-stating. I had the Shop Sabre 23 quoted and that was my understanding regarding the spindle.... That it required a different controller setup and wiring and would not be cost effective to update in the field from a router to spindle. I will have to check back on that for additional info.
    No apology necessary we just want to make sure you get what is necessary for making your decision.
    The spindle absolutely can be added in the field down the road - you could also retro-fit your own if you choose to do so, ShopSabre just would not support that non-OEM component.
    You will have some upgrades you will do in the field yes but it is possible to do.
    Give us a shout, we are happy to help.
    Aug 2019
    4
    Getting precise information from Camaster and especially ShopSabre is quite difficult. They want to keep it very closed. That fact makes me very cautious and putting off and I think I am not only one who is repelled from buying the machine from them. I want to know in advance what are my option with future upgrades and want to be open to third party products and that is the problem.
    Jul 2018
    6341
    Hi umnik - If you have the budget go with shopsabre. Seems they are keen just call them and ask Q's they seem to be open not closed. To get precise information requires precise questions a phone call usually sorts that sort of thing. Peter
    Jan 2016
    69
    I got a 4x2 ft Avid Pro last November with all the options. Am in process of adding the plasma option right now. Machine is great, i can extend it in the future all the way to 10’ long.
    Ask me any questions.
    Sent from my iPhone using Tapatalk Pro
  1. Avid Benchtop Pro 2424 Clearpath Servos
    By dermeister545 in forum Avid CNC
    Last Post: 07-24-2021, 10:17 PM
  2. Avid CNC Benchtop Pro 2424 vs. Axiom Basic AR4 Rigidity
    Last Post: 09-28-2020, 11:43 PM
  3. Questions for Avid CNC Benchtop Pro owners
    By HuguesP in forum Avid CNC
    Last Post: 06-08-2020, 03:09 PM
  4. Wanted: Avid CNC / CNCRP Benchtop PRO 2424
    By salvagedcircuitry in forum For Sale Only
    Last Post: 06-04-2020, 07:07 PM
