586,094 active members*
4,025 visitors online*
    Sep 2005
    274
    Macro variable name
    Hello, I want to have a name for each of the permanent variables I use like #500 TAILSTK this is on a fanuc 0i control, seems like I did this on another 0i but I cant get this to work, tryed the setvn in MDI with no luck, is there a parameter that needs to be turned on? Thanks
    Jan 2014
    106
    Quote Originally Posted by positiverake View Post
    Yes you can do it. We do it with 0i-MD controls.
    I would have to look for parameters.
    You want a comment to disllay in the macros page? Or you just want to declare variable names for use within that program?
    Sep 2005
    274
    Re: Macro variable name
    thanks for the reply, yes I want to just display in the variable page
    Sep 2019
    6
    The Variable Names that you register will only be visible from the Pattern Data Menu, the variable page will not display them.
    Here is a copy of our O9501:
    You can extrapolate from here, or reference your Parameter Manual Appendix-A for the Character Code List.
    If you figure out a way to get the names to display on the variable page, please let us know!
  1. Accessing Macro Variable from another macro
    By ex-egll in forum Mach Wizards, Macros, & Addons
    Last Post: 02-01-2014, 06:52 AM
  2. Macro b variable order
    By Diggitdude in forum Parametric Programing
    Last Post: 01-13-2014, 06:02 AM
  3. Macro Variable #500
    By DruMor in forum Haas Mills
    Last Post: 11-28-2013, 03:50 PM
  4. Macro/Variable Programing
    By chadr03 in forum WinCnc
    Last Post: 02-02-2011, 02:00 PM
  5. Macro Variable Lock
    By James L in forum Haas Mills
    Last Post: 07-23-2009, 02:29 PM
