(nuts) to the DONK!!!!!1
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
our shop only ever deals with 6061 aluminum and most of our programs have run enough times (or high enough quantities) that most errors end up coming from dull tooling deciding to pop or...well the most common human error
well, there is a can of worms if i ever saw one....
In general in our shop there is no walking away. If the job is in its first path and a guy walks away he might as well keep walking out the door.
Once a job has been proven most jobs are too short to go far. The few jobs that have long runtimes and are proven out will get usually run during working hours, with someone competent at least near the machine. A few even after, but that are usually only the bosses and most senior cnc people.
Being one of the bosses, I know the dangers that I encounter. We have in 24 years not have had major problems with any of our machines.
If you are a boss, well it is your machine. If you are not, it depends on what your boss says. "The boss cannot delegate responsibility to the operators!"
P.S. In case you are wondering, nobody has walked out that door yet either.
Rules of my Road: Don't do what you will regret! Never regret anything you do!
Don't be too confident. We have a VF0 that ran for six years without any problems machining 6061. One day doing a job that had been done thousands of times with a 1 hr cycle time it did not pick up a tool correctly, rammed the partially gripped tool into the work so it wedged sideways in the taper and proceeded to try burn the pull stud away against the inside of the spindle taper halfway up. It only took about 5 or 6 seconds before someone got to the red button but that was too late.
Needless to say the runout in that spindle now exceeds the manufacturers specs.
weve definatly had our fair share of 'unknown errors' we run an eleven machine mill department, all haas machines ranging from 1997 model vf-1's vf-2ss vf-3 with rotary and our newest is an MDC 500, unfortunatly some of our employees think that they are smarter than newton and decide to make changes which once in a while turn into fried bearings in spindles or smoked boards...my favorite (just this last week) one of our button pushers decided the lights were dirty and sprayed them down with his coolant hose, needless to say haas will be out tomorrow to fix the 'ground fault error'
you know the best thing about cnc is that it will follow the same path over and over and over until it is told to change, after watching the machine run a couple of parts and you know it does that part fine without crashing, than yea i wouldn't feel bad leaving it while it ran. Just don't forget it.
thanks Tim Clay:rainfro:
Walk away?
You have ran the program and machined a good part (actually 100 parts). That indicates you are satisfied with the program, and the quality of the parts coming off the machine - no mention of any problems with dimensions, finish, flushing chips away from the part, or coolant being misdirected. Also, you apparently have had no tool changing problems.
So, these are some things to check, or consider, before walking away:
1. Is the coolant tank full?
2. Is the path from your office to the machine clear and uncluttered?
3. Can you listen to the machine from your office and therefore be warned if something sounds wrong?
4. Are the cutting tools in good condition?
5. After replacing a tool, stay with the machine during that tools' first use - tool pickup, use, and replacement back into the tool drum.
6. If there are other personnel around, let them know that the machine is not being watched.
7. As each part comes off the machine, look it over for any indications of tool fatigue.
8. Is there a time demand/delivery schedule that keeps you away from the machine?
9. If your other work can be brought near the machine, so much the better.
Very wise words. I used one of them baby monitor thingies (can't remember what it's called)- you know the things you put in your baby's bedroom so you can listen to them downstairs. I could then happily carry on my Acad work in the office content that nothing too bad was happening to the machine.3. Can you listen to the machine from your office and therefore be warned if something sounds wrong?
As an aside- you can't cover everything- a few years ago the guys in the lab were extremely amused to see me sprinting into the machine area, punching the E-Stop and pulling all the 3 phase power plugs. The reason? an electrical storm had just started outside- the last time this happened it fried the PMAC board- about £5K damage and a week downtime re- calibrating and setting up the machine.
I love deadlines- I like the whooshing sound they make as they fly by.
Several years ago I was with a company that considered using such a remote to control a hydraulic winch system. We were using a national professional hydraulic manufacturer for this system. They assured us that such remotes were available off the shelf, and that they were reliable enough through redundant, encrypted, acknowledged two-way coms, and that they were not succeptable to false triggering.
Steve
