The development team is pleased to announce version 1.8 of the RosettaCNC software downloadable from the download page:
Download Page
Changelog 1.8.5 vs 1.7.9
- Improved UI features:
- Added customization of Top Toolbar.
- Added customization of Left Toolbar.
- Added control bar with Main View and G-Code editor.
- Added custom descriptions for User I/O and Analogic I/O.
- Added customizable DRO View for Feed and Spindle panels.
- Added DRO fields for Feed and Spindle as Motor Torque, etc.
- Added custom descriptions for AUX/PLC/Advanced parameters.
- Added units & descriptions for Input/Shared/System/Protected parameters.
- Added new icon to describe Access Level feature is disabled.
- Added new G-Code Analysis management.
- Added new info pannel when Jog Soft Limits are disabled.
- Added more digits for axis positions in Program and Machine view.
- Added new File -> Open Application Data Folder.
- Added setting to disable G-Code editing (read only).
- Added new G-Code editor menu Resume From This Line.
- Added new Functions -> Macro Management to view and crypt macros.
- Added new Overrides controls for Feed X+ and Feed X- OVR.
- Changed Resume button to be Resume From Pause or Resume From Stop.
- Extended available space for the first catched Alarm Message.
- Moved Overrides controls from Work panel in the new Overrides panel.
- Improved G-Code editor as wil be reported below.
- Improved management of compiling phases.
- Improved 3D view modes in toolbar.
- Fixed File -> Open Sample... to get right samples folder.
- Improved Board Monitor management:
- Improved Info panel with more info about CNC Board and Order Code.
- Improved User Input panel info and features to force inputs state, etc.
- Improved User Output panel info and features to force outputs state, etc.
- Added multilanguage support for all custom texts.
- Added new Fixed Distance with CTRL + Fast Click parameter for UI Jogs.
- Added new sample macros to support new CNC Board features.
- Added homing management for U/V/W-axis.
- Added new Virtual Machine EVO-1000.
- Completed support for mm/inches.
- Improved DRO to show TCP positions for Program & Machine.
- Improved ToolChange to support more MTC/ATC scenarios.
- Improved ATC Management macros to work with Tool Change macro.
- Improved panel to notice the state of feature Jog Soft Limits Disabled.
- Improved Overrides management.
- Improved Resume after STOP and Resume after STOP from line.
- Improved EtherCAT Board CNC errors management.
- Improved 3D management of transparency objects order.
- Improved online update management.
- Completed M166/M168 implementation and related #5740..#5755 params.
- Added full support of Metric/Imperial units mode.
- Added new Access Level locked features:
- Edit of G-Code in the Program Editor.
- Force of Digitals and Analogics I/O Values in Board Monitor.
- Added new G-Code editor features:
- Added auto-complete engine activable with ALT+Space.
- Added customizable dictionary engine activable with CTLR+J.
- Added Resume From This Line management.
- Improved Resume from Stop and Start From Line management.
- Improved interpolatator to support Motion Dynamics and Jerk Control.
- Improved 3D Scene Engine:
- Added new cursors for Pan/Rotate actions.
- Added new View Modes as Initial View and User View Mode:
- Front/Back/Top/Bottom/Left/Right/ISO 1..ISO 6/Custom View 1..4.
- Fixed STLs ugly drawing when objects are very far from camera.
- Improved ATC Management pannel:
- Improved operations to manage all cases.
- Improved macros to use named parameters.
- Improved Virtual Machine Engine:
- Added shader engine.
- Added menu to Replace a geometry.
- Added menu to Move a geometry in another machine/axis part.
- Added scale parameter to resize geometries.
- Added geometries contour edges management.
- Added toolbar with geometry File Name and Triangles count.
- Completed MDI integration to support all CNC features.
- Improved MDI panel with more info about CNC states.
- Improved GCode languange:
- Added start.ngc macro called at program start.
- Added restart.ngc macro called at program resume.
- Added pallet_shuttle.ngc macro called at M30/M60 execution.
- Added encrypted macro management.
- Added G68.2: 3D plane rotation (arcs not supported).
- Added G102: Homing request.
- Added G103: Set traverse rate.
- Added G104: Set interpolated motion dynamics.
- Added M1: Program optional stop.
- Added M48: Enable the feed rate and spindle speed override controls.
- Added M49: Disable the feed rate and spindle speed override controls.
- Added M50: Enable/disable the feed rate override control.
- Added M51: Enable/disable the spindle override control.
- Added M67: Read analog input.
- Added M68: Set analog input.
- Added M166: Read digital input group.
- Added M167: Read analog input group.
- Added #5081..5086: Current TCP position when restarting X..C.
- Added #5091..5096: Last stop TCP position X..C.
- Added #5127: Active Jerk.
- Added #5128: Active max acceleration.
- Added #5129: Active max deceleration.
- Added #5136: Active feed override mode.
- Added #5137: Active spindle override mode.
- Added #5139: Active traverse rate.
- Added #5730..#5739: User input values from M109 or M120.
- Added #5740..#5759: Input values from M167.
- Added new <#sys.xxx> constants.
- Added new <#math.xxx> constants.
- Added new <#cnc.xx> constants.
- Added new <#compile.xxx> constants.
- Added new <#axis.xxx> constants.
- Added new <#tool.xxx> constants.
- Added new <#wait_input.xxx> constants.
- Added new <#pick_place.xxx> constants.
- Improved M109 to permit multi-entry fields.
- Improved compiling errors messages management.
- Moved application data to user application data roaming folder.
- Fixed Model transparency management.
- Fixed issue in edit of some fields with decimal points.
- Fixed and improved ATC Management interface to macros.
- Fixed Virtual Machine transparency management for Model.
- Fixed compiler issue with G43.2.
- Fixed compiler issue with #100..499.
- Fixed missing Tools Library save when modified with G10 L1 command.
- Fixed visualizzation of M48/M49/M50/M51 states.
- Fixed algoritm to enable Resume from this line action.
- Fixed start axes limits check when G43.4 compensation is already active.
- Fixed English and Italian translation texts.
- Fixed reported issues.
- Added new firmwares for Board-A/B 1.41:
- Aligned features with INTERFACE LEVEL 8.
- Added new Gantry axes management.
- Added gantries management in case of set to "Use slave motor control".
- Added new CNC Board state RETRACT.
- Improved I/O management.
- Improved Spindle management.
- Improved Withdraw/Retract Tool at Stop management.
- Fixed PAUSE input management.
- Fixed dynamic offset management.
- Fixed spindle state after a retract.
- Fixed M166/M167 management.
- Fixed setup data integrity management.
- Fixed Alarm state when toolpath overlap software limits.
- Changed Board-A/B OS to version 1.12.26:
- Added new command to set software limits tolerance.
- Updated profile generator to support new Jerk limitation.
- Added point acceleration/deceleration set during interpolation.
- Improved interpolation performances.
- Fixed override management with little value changes.
- Fixed stop command during a dwell command execution.
- Fixed TCP speed calculation with some kinematic configurations.
With RosettaCNC: YES YOU CAN DO!!!
