586,058 active members*
4,233 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Centurion 6 homing procedure
    Feb 2018
    109
    Just got this machine running and trying to home the machine. I power the machine on, hit the reset button to power the drives, then select Home and hit the cycle start button but nothing happens - the screen goes back to the main screen but nothing moves. I can do a Home Here and jog all three axis manually.
    Aug 2005
    42
    Re: Centurion 6 homing procedure
    Hi, You need to talk to the expert in service for Milltronics.
    He is on the forum
    Sportybob
    Bob M
    952-288-6340
    [email protected]
    Feb 2018
    109
    Thanks - I was thinking this might be a simple matter of me not doing something that I should have been doing so I didn't want to bother Bob. I ended up calling him and he got the problem sorted out for me. Someone had set the homing order numbers like -10, -20, etc. Needed to be reset to 2 for x, 2 for y and 1 for z. Also had a couple other settings that needed to be changed. Still have a problem keeping it from homing (the Z axis is binding at the top of travel) but the homing routine is running now. Another step closer to a running machine. Now to tear into the Z axis and see what it causing it to bind up!
    Bob is a fantastic resource on these machines!!!!
    I had an alignment problem on my Z axis also. It took out the servo drive. Had to have it rebuilt. The mounting block for the ball screw has a 1 inch mounting pad. the mounting screws were 1 1/4 long and the threads pulled out somewhat. (out of alignment). It comes down to duty cycle. I put in 1 3/4 long bolts and back in alignment. I don't know if someone replaced the ball screw, that used 1 1/4 bolts. You might want to check that. IMHOP. I don't know how to post an attachment, or I would show you a picture. My first time posting.
  1. partner 0-5 centurion 5(homing problem)
    By irtaza in forum Milltronics
    Last Post: 09-27-2022, 10:22 PM
  2. PCC Olofsson PTH – 2015 Homing axis procedure
    By Kuziem in forum Machinery Manuals / Brochures
    Last Post: 04-25-2022, 04:51 PM
  3. homing procedure
    By maki in forum PlanetCNC
    Last Post: 04-11-2020, 04:40 PM
  4. Sharnoa HPM-30 homing procedure Tiger 7
    By Floriptoolworks in forum Uncategorised MetalWorking Machines
    Last Post: 11-05-2019, 05:13 PM
  5. Homing Procedure Reversed.
    By helijet in forum DIY CNC Router Table Machines
    Last Post: 01-21-2013, 04:41 AM
