586,103 active members*
3,697 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Feature Request: No Tool Lift
Results 1 to 3 of 3
    Mar 2016
    18
    It would be nice if there were an option to prevent tool lifts on linking rapids. I've been manually generating trocoidal roughing paths and having to manually adjust the rapids to the next cut to eliminate tool lifts is quite laborious. A negative safe clearance option works to a degree, but it always has some tiny z height spike that needs to be cleaned up manually (a bug?), and it also sets the start and end z heights to the same level, which is undesirable. It's also quite finicky and depends greatly on the box-region you currently have defined.
    Dec 2011
    97
    Re: Feature Request: No Tool Lift
    Quote Originally Posted by jsmith5585 View Post
    Would it help to increase the cut-link distance of the tool?
    Mar 2016
    18
    Quote Originally Posted by MitchB View Post
    This would help prevent tool lift, but it would also move at cut speed instead of rapid speed, which is even slower than retracting and rapiding.
  1. Feature request
    By yar20 in forum PlanetCNC
    Last Post: 04-25-2018, 10:41 AM
  2. Feature request - ref THD
    By barbter in forum NCPlot G-Code editor / backplotter
    Last Post: 04-07-2013, 02:49 PM
  3. Feature Request
    By TURNER in forum NCPlot G-Code editor / backplotter
    Last Post: 07-03-2008, 01:56 AM
  4. Feature Request
    By robinsoncr in forum MadCAM
    Last Post: 08-06-2007, 04:03 PM
