586,058 active members*
4,716 visitors online*
    Jan 2017
    36
    Adding a laser head to a CNC Router
    Hey all I have a cnc router based on a 6040T, It run by a Gecko G540, ESS Ethernet smooth stepper and Mach 4.
    Id like to add this laser head found here: https://www.ebay.com.au/itm/30W-Laser-Module-Laser-Head-450nm-Blue-Lase-for-Laser-Engraving-Machine-Parts/224170532079?hash=item34319adcef:g:Cb4AAOSwUaFfbid o&frcectupt=true&autorefresh=true
    What else do I need to get it work and be controlled by mach 4?
    Apr 2004
    5737
    Re: Adding a laser head to a CNC Router
    Be careful about doing that. Cutting lasers can be extremely dangerous in ways that are hard to predict. There's a reason commercial laser cutters are totally enclosed with safety interlocks that turn the beam off when a hatch is opened. If it happens to shine on anything reflective, it can send a beam right into your eye, if it's not fully enclosed. So the enclosure is a must. Here's some advice on the subject from Hackaday: https://hackaday.com/2016/06/29/tami...-laser-cutter/
    Andrew Werby
    Website
    Jan 2017
    36
    Quote Originally Posted by awerby View Post
    My machine is actually already in a enclosure with acrylic windows so that’s a win
    I also have a vacuum that extracts dust and excess mist from my sprayer
    Good tip on fitting a cut-off switch of the door is opened tho.
  1. Adding 3D print head to my 10 year old scratch built CNC
    By Mr.Chips in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-13-2020, 06:22 PM
  2. adding a diode laser to a cnc 3 axis router
    By pipsi in forum DIY CNC Router Table Machines
    Last Post: 02-26-2016, 11:28 AM
  3. Replies: 2
    Last Post: 05-27-2013, 03:50 AM
  4. Adding a laser to a CNC router
    By MansfieldMatt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-12-2012, 11:52 PM
  5. Adding a laser to gantry router questions
    By SScnc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-09-2011, 07:06 PM
