586,060 active members*
3,555 visitors online*
Results 1 to 11 of 11
    Sep 2015
    12
    Vertial milling machine
    Hello, i work on some weekends on my first cnc vertical mill. The progres is pretty slow due to time and money. This is what i made so far. All parts still needs to be machined, squared and so. For the guides i have 25mm thk for the y axis. The rest for the z and x axis needs to be purchased, but i'l go with 25mm. Here are two videos with my progress so far. Thank you for watching.
    https://www.youtube.com/watch?v=B1kdXgYmyXk
    Jul 2018
    6339
    Re: Vertial milling machine
    Hi Calin - Heavy metal is looking good. Peter
    Sep 2015
    12
    Thank you!
    Jul 2012
    102
    Your 1 axis "surface grinder" is very cool
    Sep 2015
    12
    Quote Originally Posted by jackjr-123 View Post
    Thank you!
    Sep 2015
    12
    Making of a nut seat for the ballscrew nut with 3 jaws lathe.
    https://www.youtube.com/watch?v=dcubuhzYXu0
    Also, how can i post a ytb video here on forums?
    1227
    Quite easily,you copy the URL of the video and then click the icon at the top of the reply page that looks like a couple of frames of old style film,this brings up a dialogue box into which you then paste the URL.It is likely to appear in your reply as a bracketed piece of text but the magic of cyberspace will make it appear in your post.
    Sep 2015
    12
    Hello, here is a video i made and i wanted to share with you where i have done a steady rest for the lathe at my work. Hope you like it guys!
    Sep 2015
    12
    New little update, working on a bt30 spindle. Here is a video with my progress so far. Thanks for watching!
    Sep 2015
    12
    Hi, i made a video of a cheap diy heat treatment owen wich is needed to heat treat my bt30 spindle. Thanks for watching, hope you like it.https://youtu.be/ZbYlLUwgPjI
    Sep 2015
    12
    Hi, i want to share with you, just another lathe toolpost drill/mill attachment made by myself. Thanks for watching!
    https://youtu.be/DWKdWV0BZ_E
  1. Milling a plastic with a CNC 770 milling machine
    By Edmond Young in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-12-2013, 02:55 PM
  2. CNC Vertial Turning Tools
    By yifei in forum Want To Buy...Need help!
    Last Post: 04-01-2012, 07:36 AM
  3. CNC Milling Machine Packages and Bespoke CNC Milling Machines
    By worldofcnc in forum News Announcements
    Last Post: 05-27-2010, 02:20 PM
