586,103 active members*
3,799 visitors online*
    Nema 34 Servo with 3/8" shaft
    Hello. I inherited an older CNT motion router from the late 90's. I'm looking to completely change out motors, drivers,and controller. The router had teknic nema 34 servos with a 3/8" shaft size. In looking around online, it looks like the standard is 1/2" shaft diameter. Does anyone make a nema 34 servo with 3/8" shaft? It would make retrofitting easier. I will attach a pic of the original motor. Thanks in advance!
    Jul 2014
    63
    Re: Nema 34 Servo with 3/8" shaft
    You can get the clearpath nema 34 clearparh servos with a shaft of that size. They aren't steppers but are drop in replacements for steppers of you want another option...
    They are more expensive than steppers but you don't need drivers then, so the difference isn't actually that large most of the time if you compare to quality steppers.
    Sent from my SM-G781U1 using Tapatalk
    Thanks for your reply. I talked with Tom Tullar at Clearpath this morning. He said that standard nema 34 started out as 3/8" shaft, but as motors have evolved, 1/2" has become standard. He did not have a 3/8" shaft servo in nema 34 size. This is the motor he recommended, but it means changing mounting blocks, gear pulleys, bearings,etc.
    https://www.teknic.com/model-info/CPM-SDSK-3436P-RLN/
    Jul 2014
    63
    Oh man sorry to hear that. So brutal when what should be a simple procedure turns into a massive research and sourcing project.
  1. Nema 23 at 12V and 1/4in di shaft??
    By sweddle in forum Stepper Motors / Drives
    Last Post: 04-06-2012, 08:19 PM
  2. NEMA 34 shaft diameter specification
    By Ferrari2007 in forum Mechanical Calculations/Engineering Design
    Last Post: 07-15-2011, 09:44 PM
  3. Nema 34, 400 oz, 3/8" shaft
    By imaracingmom in forum Want To Buy...Need help!
    Last Post: 10-16-2009, 03:52 PM
  4. Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft
    By DonW in forum DIY CNC Router Table Machines
    Last Post: 03-17-2008, 09:58 PM
  5. 1/4 to 3/8 nema 23 shaft
    By dgalaxy in forum Stepper Motors / Drives
    Last Post: 12-16-2006, 07:28 AM
