586,096 active members*
3,396 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP 100 Battery alarm 4035
Results 1 to 8 of 8
    Sep 2006
    222
    Machine Macturn350 OSP100
    4035 ALARM- D Memory board/battery change 2
    2) A a certain period has passed since the software was initialised installed
    Has anyone instructions for this? Is there date in parameters which should be change after battery replace?
    GB
    Apr 2009
    1262
    Re: OSP 100 Battery alarm 4035
    The battery has a set timer on it that will go off weather the bat is going dead or not. You can go to the battery page in your parameters and advance it a bit to get rid of the alarm temporarily but it’s best to replace it and set the date ahead by the several years as recommended. Was it seven? I forget...maybe my battery is getting weak... ;-)
    You will probably have to unhide the parameter page using display change.
    Best regards,
    Experience is what you get just after you needed it.
    Sep 2006
    222
    I have not found battery info page on OSP100 ? Which parameter page is it ?
    GB
    Aug 2011
    419
    What is the OSP100?
    U100 , E100 or P100, which?
    "Imagination is more important than knowledge."
    Sep 2006
    222
    it's U100L
    Model year:2003
    Sep 2006
    222
    Designer of this battery system has drinked sake. A lot.
    I found instructions here:
    https://www.practicalmachinist.com/v...cedure-277828/
    Biggest problem was to found 3,5 inch floppy...
    Good luck to anyone with this problem.
    Jun 2018
    OSP 100
    Is the control model information
    Jun 2018
    Does anyone have the procedure on how to replace the batteries
    on the osp 100 and t he osp 200
  1. 2100 NCK ALARM 810D - NEED TO CHANGE BATTERY - WHERE IS THE BATTERY LOCATED?
    By scottbryce in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-22-2021, 07:35 AM
  2. Alarm 4035
    By dinoeko9 in forum Okuma
    Last Post: 10-31-2017, 01:12 AM
  3. Replies: 5
    Last Post: 03-07-2017, 06:15 AM
  4. Memory board/battery alarm 4035
    By lmbma in forum Okuma
    Last Post: 06-17-2014, 03:39 PM
  5. 4035 Alarm-D
    By energyzer in forum Okuma
    Last Post: 05-16-2012, 12:59 AM
