586,409 active members*
3,045 visitors online*
    Mar 2020
    Mazak H400 M32 Variation at Y axis
    Hello, we have a problem with a horizontal mill Mazak H400 M32 control.
    When machining a circle, X axis machining is correct, meanwhile Y axis has 0.07 inches less of cut.
    Did someone know if i can modify a parameter to adjust this difference?
    Or by the other hand, some one has the parameter manual?
    Sep 2012
    217
    Re: Mazak H400 M32 Variation at Y axis
    Quote Originally Posted by Meka1292 View Post
    For that amount of variation i would be looking at a mechanical issue or maybe an encoder drive issue before trying to change backlash parameters
    Regards Bob
