586,032 active members*
2,852 visitors online*
    Feb 2008
    8
    Torq Cut Tool Changer Thyristor Failing
    First, apologies - I know there were some old threads on this subject but I can't find them anymore...
    I have a Torq Cut 22/DX32 VMC. Every few months, the thyristor (Grayhill 70M-OAC5A) which controls the "out" direction of the tool changer fails on the LC-TLAUF board. I've now replaced it three times in two years. Any ideas about the root cause of this problem so I can eliminate it?
    TIA,
    Mark
    Aug 2009
    1573
    Re: Torq Cut Tool Changer Thyristor Failing
    ...possible failing Solenoid Coil drawing to much current (amperage) for the relay to handle. Looks like that 70M-OAC5A Relay is rated 3 amp
    https://www.digikey.com/en/products/...M-OAC5A/180934
    Nov 2012
    1267
    You should definitely check the coil and compare its DC resistance with a known good one. Also check if the "IN" relay gets hotter than the "OUT" relay during operation.
    Another possible reason is an intermittent short in the wiring.
  1. Replies: 13
    Last Post: 01-17-2019, 02:01 AM
  2. Torq-Cut 22 random alarm... Tool changer not safe...
    By DarkStarMedia in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2016, 06:48 PM
  3. Bridgeport torq cut 22 tool changer woes
    By lampguy in forum Auto Tool Changer
    Last Post: 04-07-2016, 08:31 PM
  4. Torq Cut 22 Tool Changer Problem
    By MetalicGlow in forum Bridgeport / Hardinge Mills
    Last Post: 12-09-2009, 02:41 AM
  5. ktk thyristor drive FAC-1R
    By gilbertroy in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2009, 04:37 AM
