586,399 active members*
3,142 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > Trimming motor brushes - how practical is this?
    Aug 2012
    279
    Have a bush motor that brushes are used up and can't find exact replacements. They are 7 x 8 x about 20 mm with a braid out the side. Have found some similar and slightly larger. Wondering how easy it would be to reduce the size, what sort of methods to use, how to clamp them without breaking, etc
    15362
    Re: Trimming motor brushes - how practical is this?
    Quote Originally Posted by Jim27 View Post
    You can do this on a Bench grinder and then file them to square them up, just be careful with the wire ( braid ) not to damage it, they need to be a good fit in the brush holder so take you time in fitting them
    Mactec54
    24223
    If not that much difference, what I do is use some medium emery paper and use hand strokes to carefully take it down evenly as possible, you do not want any slop if possible as it causes premature wear.
    If there is a fair difference, use coarse paper at first.
    Have a digital caliper handy to check fit.
    Al.
    Albert E.
  1. Fanuc DC motor Brushes
    By Al_The_Man in forum For Sale Only
    Last Post: 02-15-2019, 05:59 PM
  2. Replacement Motor Brushes For Sherline Mill AC Motor
    By Lessons in forum Benchtop Machines
    Last Post: 07-17-2010, 02:34 AM
  3. Motor brushes
    By rog8811 in forum Want To Buy...Need help!
    Last Post: 12-28-2008, 11:28 PM
  4. dc motor brushes supplier
    By DrStein99 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-02-2007, 04:22 AM
  5. where to get interact 4 motor brushes
    By camarogod98 in forum Bridgeport / Hardinge Mills
    Last Post: 02-15-2007, 01:12 AM
