586,068 active members*
4,307 visitors online*
    Aug 2020
    15
    3018 cnc universal gcode sender
    I have a 3018 and am trying to use Universal Gcode Sender. I have a DFX-Gcode file made with CamBam. The problem is when I load the gcode the project lands too far from the cnc machine. See circled object on attachment. How can I make it land at "X"?
    1227
    Re: 3018 cnc universal gcode sender
    Trying them all eh?How about going to the .dxf and moving the whole entity closer to the origin?Additionally,check the default units on all the software you are using.
    Aug 2020
    15
    Quote Originally Posted by routalot View Post
    Yep I cant see spending a lot of money on really good software or good machine until I can get rid of my mental block on this issue.
    I have done all that. Created DXF in mm. Set everything to mm. Created drawing at page origin in AutoCad. Tried the same with other CAD programs (FreeCad, TurboCad) tried converting Inkscape to DXF, Tried directly generate Gcode from inscape.
    Anyway thanks for responding.
    1227
    I use Freecad and find it very good.Did your program run successfully when you used the simulation feature?Additionally,when you set the preferences did you go to units and select "metric small parts and CNC"?Then when you set the preferences for the Path module,which post processor did you choose?As i posted on the other thread about the problem pasting the first fifteen or so lines of the program here may provide clues.
    Aug 2020
    15
    Actually I prefer AutoCad. FreeCad tends to quit responding on my machine a lot.
    Mike
  1. Replies: 2
    Last Post: 01-31-2020, 01:55 PM
  2. Replies: 4
    Last Post: 03-27-2019, 11:19 PM
  3. Help with Universal Gcode Sender
    By rfresh737 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2016, 12:17 AM
  4. Universal Gcode Sender Z Axis Help
    By rfresh737 in forum Arduino
    Last Post: 01-26-2016, 06:46 PM
  5. Universal Gcode Sender Z Axis
    Last Post: 01-26-2016, 05:10 PM
