586,106 active members*
3,072 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak Mazatrol 640T Parameter Error 26 after replacing battery spindle
    Oct 2020
    Hello,
    Can anyone please help.
    First problem was that the battery had to be replaced. This was done with an original battery of the vendor. Now the machin is starting. On the main panel the red light Alarm is showin. The Windows OS is booting but when the mazatrol software open you only can see the red error "Parameter error 26".
    Can anyone help ?
    Best regards
    Gernot
    May 2019
    15
    Re: Mazak Mazatrol 640T Parameter Error 26 after replacing battery spindle
    Hallo, please give your mailadresse so I can contact you.
    Gesendet von meinem SM-N950F mit Tapatalk
    Nov 2020
    Hey, i'm sorry. Can anyone help me? After replacing the batteries, the spindle does not want to accept the replacement numbers.
    May 2019
    15
    Quote Originally Posted by Arni89 View Post
    Was ist das Problem gib eine mailadresse
  1. PC-NC_I/F error Mazatrol 640T
    By wiktorkreft95 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-01-2019, 12:13 PM
  2. Mazatrol 640T, Nexus 100, battery alarm LED
    By toba in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-13-2015, 05:34 PM
  3. mazak qt 200 640T back up parameter
    By movick_25 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-11-2012, 03:17 PM
  4. mazak 640t decimal format parameter ?
    By rapid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-29-2011, 09:27 PM
  5. PARAMETER MAZAK SLANT TURN 30 WITH MAZATROL T1
    By tonny2105 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-06-2010, 09:30 PM
