586,052 active members*
3,953 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Automated Camera Operator - 7.2 Metre X axis 3.53 Metre Y axis 2.34 Metre Z axis
    My goal is to create a camera operator that replicates shots that I demonstrate to it. For that in my research, I need to create a 3 axis system at least.
    The X axis needs to be 7.2 Metre X 2
    Y axis at 3.53 metre X 1
    Z axis at 2.34 metre X 1
    for X axis, I would join two rails with flat butts together with one inversely positioned so the gaps are not the same. I also think maybe the y axis needs to be 2 instead of one.
    The camera equipment (approx 3-4kg) sits on a moving carriage on a stable Z axis. I would use a displacement sensor and a breaking motor on the z axis, alongside stepper motors with belt drive on other axis.
    I have discussed this with a couple other people who say that the load on the x axis might be too much for the belt since the length is long. That instead I should use steel ropes and a pulley mechanism.
    What are your thoughts? I would deeply appreciate your help. Where possible please include the components needed and their configuration.
    Any additional help is also appreciated.
    May 2016
    316
    Re: Automated Camera Operator - 7.2 Metre X axis 3.53 Metre Y axis 2.34 Metre Z axis
    Internet search for Bell-Everman servo-belt, specifically the "Looptrack" design. Inexpensive way to get really, really long travels without the drive system tension warping the structure.
    Alternative is a rack & pinion, but that'd get really expensive for that much travel.
    You could skip using linear rails and just use wheeled trucks that ride on/in aluminum extrusions. It won'd be very presice, but you can fiddle with it until it's smooth enough for good photography.
  1. Replies: 0
    Last Post: 04-27-2016, 04:08 PM
  2. CNC programer/operator 3 axis and/or 5 axis
    By Plasticman-nc in forum Employment Opportunity
    Last Post: 08-21-2014, 01:37 AM
  3. Sources in Australia for 4 core shielded cable (by the metre)
    By cnc3678 in forum Australia, New Zealand Club House
    Last Post: 05-01-2012, 11:21 AM
  4. 6.5 metre Travel.
    By Firetrap in forum Open Source CNC Machine Designs
    Last Post: 01-20-2010, 09:28 PM
  5. 1 metre long Internal Threading..Any ideas ??
    By intelsingh in forum MetalWork Discussion
    Last Post: 01-09-2010, 06:58 AM
