586,068 active members*
3,652 visitors online*
    Jun 2005
    104
    EZ Trak Emergency Stop
    I recently purchased, what should be about a 2000 3-axis EZ Trak mill that has been setting for a several years. The machine powers up and completes the BMDC test but I cannot clear the E-Stop Alarm. The E-Stop button on the Operators Control works. The oil reservoir is full. Motor Overload isn't tripped. I've got a few other EZ Traks that I have had for about 15 years so I know my way around these machines pretty well. This one has me stumped though. I had to top off the oil reservoir before firing it up so i'm a little concerned that the Lube Level switch may not be closing. Can anyone give me some guidance on checking it or some other area that I may be overlooking? I've attached images of the BMDC card just in case I missed something on the indicator lights.
    Aug 2008
    9
    Re: EZ Trak Emergency Stop
    Good morning, I trust you have a multi meter preferably a DVM. I would check continuity of the overload Normally Closed contacts to make sure that the haven't become resistive since this machine is old and has been sitting dormant. Also the lube oil level switch should be a closed contact if the oil level is sufficient. Since this machine is a 24 vdc control system, All these normally closed contacts better have less than 1 ohm resistance or you will have problems in the E-stop loop. And if memory serves me correctly, the spindle motor has a normally closed thermostatic switch which May be wired into the E-stop loop. I hope this helps. You can drop me an Email to [email protected]
    Best,
    Rick Macy
    Jan 2021
    4
    I was having the same issue, I discovered that the work light was shorting out inside. It is on the same circuit as the e stop on my machine it was blowing the (FU12) fuse and was acting as the Estop. I put new lights in and cut out the factory light and replaced the fuse and it eliminated the issue.
    My mill is a Bridgeport VMC 760/22.
    Hope this may point you in the right direction.
  1. Problems with Emergency Stop/Stop function.
    By MrEmo in forum PlanetCNC
    Last Post: 10-19-2021, 10:47 AM
  2. emergency stop condition after E stop
    By Cosmin90 in forum Fadal
    Last Post: 01-14-2020, 01:30 AM
  3. EZ Trak emergency stop
    By reabdet21 in forum Bridgeport / Hardinge Mills
    Last Post: 01-07-2012, 07:34 PM
  4. Generic Emergency Stop (E-Stop) Design Concepts?
    By zipzit in forum CNC Machine Related Electronics
    Last Post: 06-09-2011, 12:14 PM
  5. Bridgeport EZ Trak emergency stop problem
    By Craiga in forum Bridgeport / Hardinge Mills
    Last Post: 10-18-2009, 05:56 PM
