586,094 active members*
4,017 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > DMG MORI CTX 310 Ecoline Turrent Help
    Oct 2020
    Greetings, I am having a issue with a DMG MORI CTX 310 Ecoline machine, the turrent wont turn to any direction. It is a Siemens control machine and the alarm given is 700036 which is turrent is not clamp in right position. The turrent is control by a delta servo and servo drive, on the servo drive I have the alarm 9 which is same condition it is not position correctly. Does anybody know how to fix this problem ???
    I tried clamping the turrent manually in diferent positions but it does not respond.
    Re: DMG MORI CTX 310 Ecoline Turrent Help
    Quote Originally Posted by Heiro15 View Post
    Maybe you can try to change the tool locking time longer by parameter, sometimes the tool change not finished yet, but the time is up, which causes the turret is not clamp in right position.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Oct 2023
    Hi there
    Do u solve the problem?Just had the same problem with u
  1. DMG Mori 635 V Ecoline washing pistol
    By Vislech in forum Mori Seiki Mills
    Last Post: 07-13-2017, 10:19 PM
  2. 371 turrent servo alarm
    By esmeralda in forum Spanish
    Last Post: 11-12-2010, 04:22 PM
  3. VF2 Turrent Fail
    By jimmck in forum Haas Mills
    Last Post: 06-03-2009, 05:50 PM
  4. SL-3H Turrent Alignment
    By TWyatt9 in forum Mori Seiki lathes
    Last Post: 03-17-2009, 12:42 PM
  5. Turrent Change on a Funuc oi-TB
    By metalmansteve in forum Fanuc
    Last Post: 11-02-2006, 11:17 AM
