586,065 active members*
4,861 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Monoprice touch screen monitor lifetime?
Results 1 to 13 of 13
    Jun 2006
    3063
    I hadn't used my 5-year old lathe for a while and powered it down for a couple weeks. I just turned it back on today and the Monoprice touchscreen monitor that I bought with the lathe fades out within a few seconds after power up. Cycling power to the monitor gets it working for a few seconds, just long enough to click a few onscreen buttons before it fades out again. Is there any chance of an affordable fix or should I just buy a new monitor?
    To make it worse, someone from Tormach mentioned that they are working on a version of the Pathpilot Operator Console for the lathe, which may be available around the end of the year and I'll probably to replace the monitor before then.
    Jan 2016
    386
    Re: Monoprice touch screen monitor lifetime?
    Quote Originally Posted by MichaelHenry View Post
    Can't help with the monitor. I heard that Tormach is releasing a new lathe soon as well.
    Nov 2007
    2151
    Rut roe!
    I have 2 of them. one about 3 years old and one about 11 months old. Hope I dont have same problem
    Jun 2006
    3063
    Well, I ordered a replacement from Amazon, which arrived today, and the old one started working yesterday so I guess I have a spare. We've had a number of power outages here so I sort of assumed that voltage spikes from one of them had done in the monitor.
    Apr 2013
    1788
    For what it is worth I purchased a Monoprice 106959 17-Inch Monitor at the end of 2015 and it is still working great. Now I've probably jinxed it! With my probable problems in mind, which monitor did you order? Please let us know if it works with PP.
    Jan 2009
    234
    Caps in the PSU... I have fixed a few of them.
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
    Jun 2006
    3063
    The old monitor is still working fine and it's replacement is in storage awaiying complete failure of the original.
    Nov 2007
    2151
    They are hard to find currently. Went to buy a 3rd and could not find any for sale.
    Jun 2006
    3063
    Quote Originally Posted by mountaindew View Post
    I got mine on Amazon, but I expect you already checked there.
    Nov 2007
    2151
    Anyone in cnc land know of touch screens that work with PP.
    I have 2 monoprice units and would like a 3rd for 8l lathe, but they have been sold out for months now.
    Are there any others that work out of the box?
    Jun 2005
    656
    I like industrial touch screens for that kind of environment as they last a whole lot longer, but anything that supports USB HID (most of the non-antique ones) will work with PP-- you might need to do an ADMIN TOUCHSCREEN to calibrate them.
    I've got an ELO and Planar touch monitors now. I used to have a 3M point-of-sale touch monitor that was awesome, but it went with my old 1100
    Industrial monitors aren't cheap new, but usually available on eBay from people scrapping out restaurants and such.
    One caveat, if you get an "Infrared" monitor (they have noticeably-deep bezels around the screen and are quite common in industrial), they work great until a chip gets in the bezel or you touch them with a drop of coolant on your finger, then they can freak out.
    IIRC the Monoprice is a 'resistive' touch technology, which is old and reliable and works with chips and coolant, but can scratch and eventually wears out. You can look for other resistive-touch monitors on Amazon if you're fine with how the Monoprice works.
    Nov 2007
    2151
    Quote Originally Posted by shred View Post
    The captive touch type work with pp?
    Search's for Linux compatible dont show much.
    Will look at brands you mention.
    I have to do something. The lathe is to distracting to use without a touchscreen. Looking up down left right all to start an operation or set a value. Should have spent the money and went with pp console.
    Jun 2005
    656
    Capacitive touch is a tricky one. "Multi-touch" monitors designed for Windows 10 may or may not work with PP. Some of them fall-back to single-touch if they aren't talking to Windows, but I have no idea which anymore as it's been years since I was deep into touch technology. Single-touch capacitive monitors may work, but there's a wet-hands and have to use a finger (no gloves) requirement kind of like phones (which are virtually all capacitive touch)
  1. UCCNC control interface.. pendant or touch screen monitor ?
    By andrewwong2000 in forum UCCNC Control Software
    Last Post: 04-21-2019, 04:26 PM
  2. Monoprice Monitor - Capacitive or Resistive?
    By jttoner in forum Tormach PathPilot™
    Last Post: 03-06-2017, 09:06 PM
  3. Acromatic 950 Touch Screen Retrofit - No Response From Touch Screen
    By csokoll in forum Controller & Computer Solutions
    Last Post: 05-27-2014, 09:41 PM
  4. touch screen monitor
    By zfjohnson07 in forum Computers / Desktops / Networking
    Last Post: 02-23-2012, 07:25 AM
  5. touch screen monitor
    By cob in forum Mach Mill
    Last Post: 11-25-2008, 04:59 PM
