586,102 active members*
2,485 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > where can i find cheap linear motion parts?
Results 1 to 16 of 16
    Jul 2007
    5
    I have a hard time finding cheap shaft, pillow and bearing. Is there any chinese parts? Is there a U.S. or canadian manufacturer that is selling cheap?
    I wanna build the best CNC router possible and i can't get used to pipe and roller skate bearing design.....
    Is there any other solution then linear motion?
    Thanks for your help
    Francois
    Jan 2007
    6
    Cheap Linear Slides
    Jan 2007
    6
    May 2005
    674
    MDF? $35 sounds pretty bad for MDF. $3.50, maybe.
    Jul 2007
    5
    35$ is for a complete axis assembly, but it still MDF....
    I'm glad they offer the same axis assembly in plastic/aluminum mix and complete aluminum for 50% and 70$, now that's cheap
    Thank you guys for your help, if you still have some cheap part source, please reply....
    Francois
    Jan 2007
    6
    For $15 more he sells a plastic-and-aluminum version and for double that you can get the all-aluminum version. It also has the screw, bearings and mounts built-in. If you can find a cheaper already-put-together hobbyist linear slide you can hook a motor to, I'd love to hear about it. (No, used parts on eBay don't count.)
    Feb 2004
    1086
    I sell a set of parts intended to mount to 8020 aluminum extrusion from my website. Right now, I only have the motor mounts and screw bearings, but I am working on a linear bearing solution as well. Also, my site currently only shows NEMA 23 mounts, but I should receive NEMA 34 mounts that work with the same system sometime next week. Feel free to check it out if interested: www.cncrouterparts.com.
    Ahren
    Jun 2006
    259
    Keling
    Keling has linear slides for pretty cheap. http://www.kelinginc.net/SlideBlock.html
    60" x 20mm for $41 and the bushing is $6.
    Linear rail is roughly $1 per cm, with blocks around $45....
    Chris.
    List of parts sources for CNC builders - http://www.CNCsources.net
    Dyna Mechtronics 4400C Conversion - CNC bed mill w/toolchanger to Mach3 conversion - http://www.cnczone.com/forums/showthread.php?t=50787
    Jul 2006
    1256
    Thanks Jerry for the VBX.
    They have 20mm round rail with aluminum support rails,50"with 2 blocks for $149.00.Sorry don't know how to read the load ratings.Dynamic con 882.Static 1370.Larken uses round rail and claims .oo1.At this price my project and other members machines may get built sooner at these prices.Perhaps Jerry could fill us in on the plus or minus on this type of rails.
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Aug 2007
    Hello from a keen CNC noob!
    Have any of you looked at these?
    http://www.rolloncorp.com/products/x_rail/index.shtml
    They look pretty good, have an eccentric to remove slop, and have huge torque ratings.
    I have to consider all options, here in Australia everything costs a small fortune!
    Jul 2007
    5
    thank you i've just order the rollon corp pricelist and catalogue. Their linear system look very nice. I hope tjey're not too expensive, if they do Athreo CNC is the way to go!!!
    Jul 2007
    1602
    The x-rail looks better suited to a car-wash than a precision machine but the Uniline series looks interesting
    Jan 2007
    6
    If you have to ask how much it costs, you probably can't afford it ;-)
    Now..have you checked eBay for THK rails and suchlike? They usually have some pretty decent deals for precision parts people are throwing out.
    Aug 2007
    147
    Larry, I have a set of those VXB rails and blocks. I tried them out awhile back when I was looking for an alternative to Hiwins. They fine for a small hobby router, but I wouldn't use them for heavy duty applications. The cost savings just isn't there. You're paying 65% cost for 20% the load capacity. You also can't get them in custom lengths, and there is a shipping fee, unlike automation4less who ships hiwins for free and charges per 100mm of rail. The wasted rail lengths + shipping fees shrinks the price gap down to about 10-20%.
    The VXBs pictured are also much more prone to contamination. One thing they have going for them is that the ball cages inside the pillow blocks are dirt cheap. You can replace them for $5.00 a pop. I contacted a supplier in China a year ago and they sold them in quantity for $1.37. So they're basically consumables.
    The VXB hardened rail is bulletproof. They're similar in quality to genuine Thomson rail, which I often use for various setup applications around the shop. You can chuck them up on a lathe with hardened steel jaws and not scratch them.
    The pillowblocks are okay. They're extruded aluminum so they won't have nearly the same precision as a ground Hiwin/THK. Probably not a big deal for most wood routers. However, what is a big deal is that the the pillow blocks are attached to the bearings with a single set screw. A bit too flimsy IMO.
    I think they'd be a good alternative if VXB could offer the rail in custom lengths and offer cheaper shipping without increasing the price. Until then, Hiwins and/or ebay THKs are far superior in terms of both overall performance and bang for the buck.
    Aug 2007
    Quote Originally Posted by bassman74 View Post
    Hey Bassman, how did you get on with the catalogue from Rollon?
    Pete
  1. linear motion parts in ontario canada?
    By elninio in forum Linear and Rotary Motion
    Last Post: 01-24-2017, 05:10 AM
  2. Where can a guy find cheap mil-spec connectors?
    By damae in forum Servo Motors / Drives
    Last Post: 07-31-2005, 04:32 AM
  3. Can you compare this two linear motion parts
    By bunalmis in forum DIY CNC Router Table Machines
    Last Post: 07-14-2005, 10:53 PM
  4. where to buy online motion parts for cheap
    By hpghost in forum DIY CNC Router Table Machines
    Last Post: 03-31-2005, 10:09 PM
  5. Linear motion
    By Wez in forum DIY CNC Router Table Machines
    Last Post: 12-07-2003, 07:54 AM
