586,035 active members*
3,712 visitors online*
Results 1 to 7 of 7
    Feb 2006
    202
    Decent motor/board/power supply kit?
    I'm helping a friend overhaul a 20 year old router. It's Nema23 (grossly underpowered at 150oz/in) and equally old Geckos. I'd like to just put on some bigger motors, but I know the PSU and geckos would be better served with an upgrade as well.
    I was looking at this "all in one" kit here from Avid CNC: https://www.avidcnc.com/4-drive-diy-...ahcta80c3e2872
    But I was wondering if anyone had any better kit to recommend?
    Little info about the machine:
    2' x 2 x 6" (XYZ), full size Porter Cable router head. Ball screws on all axis, 1" Thompson shaft and bearings on XY, 3/4" on Z. All aluminum (machined flatbar) construction. Dual ball screws on the lower (X) axis, using a single motor and timing belts to transmit motion.
    Planning on using Mach3/4, if that matters at all. Computer choice is rather open ended, from old XP machines all the way up to Win10 new PC.
    Re: Decent motor/board/power supply kit?
    Check out HobbyCNC.com
    WoodWorkerB
    HobbyCNC.com, WoodWorkerB.com
    You rarely see kits with top of the line components, due to the price.
    The only other seller of package kits I know of is here:
    https://www.automationtechnologiesin...23-4-axis-kits
    Feb 2006
    202
    Thanks for that link! To clarify; not looking for top of the line components, just something "decent" to get the machine back up and running
    -EDIT-
    In your opinion, would I be better off piecing together a kit with better components? If so, where should I start my search?
    Motors
    Power supply
    Drives
    Breakout board
    I guess it depends on how much you want to spend.
    This is probably a pretty good kit.
    https://www.automationtechnologiesin...-stepper-motor
    I prefer UCCNC over Mach3. CNC Drive's AXBB-E controller doesn't need a breakout board, and can also be used with Mach3 or Mach4 in Windows 10.
    May 2015
    686
    I'm not so sure. I will not buy motors which do not have torque curves available. This one does not even quote motor inertia which in my modelling is one of the most important critiera for motor selection. That and the ratio between induction and resistance. The manufacturers of good motors don't always make good drivers or they simply rebadge another brand
    Rod Webster
    www.vehiclemods.net.au
    Jan 2016
    69
    The Avid CNC RouterParts kit is very good. That is exactly what I have and have been using for a year.
    Sent from my iPhone using Tapatalk Pro
  1. Tachus42 board power supply
    By shreifali in forum Stepper Motors / Drives
    Last Post: 10-18-2014, 11:24 PM
  2. Fanuc Power Supply board
    By andrewklay in forum CNC Machine Related Electronics
    Last Post: 08-11-2014, 07:55 PM
  3. DIY Controller Board Power Supply
    By Fish4Fun in forum Open Source Controller Boards
    Last Post: 03-29-2007, 09:43 PM
  4. Building a power supply with decent volt/amperage
    By phantomcow2 in forum CNC Machine Related Electronics
    Last Post: 03-14-2006, 11:33 PM
  5. 30v dc power supply for the xylotex board?
    By ljoe1969 in forum CNC Machine Related Electronics
    Last Post: 01-19-2006, 03:50 AM
