586,035 active members*
3,633 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Step motor losing steps - no load
    Mar 2012
    7
    Question Step motor losing steps - no load
    Hello everyone,
    I finally started building my first CNC machine. And I done it and I am proud of it. However I have one problem that I failed to manage. I notice when I run some G code that have strait lines it works ok, sometimes I notice that it doesn't return to same position but I was still experimenting with speeds and acceleration so I thought that was the problem.
    However I noticed that with code that doesn't have straight lines, but rather contours and G code is point next to point generated by MasterCAM i loose steps a lot! For test I took only part of G code that lasts 1min 17 seconds with adjustments 400mm/s and 20mm/s^2, 80 steps per millimeter and I notice that I lose about -0.5 millimeter when I return to same position x,y,z(-2,0,0). And I always loose steps in same direction!
    To diagnose this problem and make sure that problem is in electrics not mechanics I took off stepper motor, I put straight part of the shaft in horizontal position at (-2,0,0) and started G code. After it finished the straight part of the shaft wasn't horizontal, but rather at some angle (30-40 degrees) which is half millimeter on the pitch of 5mm. If I put it to run 1000mm, motor rotates and finish in the horizontal position (5mm pitch, so one full revolution, 400 steps per rotation, 80 steps per millimeter).
    Also to make sure that correct signals are coming to the stepper driver I made circuit that counts steps with PIC microcontroller, divides steps by 8 and show on the display. I start G code and when I finish code at -2,0,0 at screen from microcontroller I also have -2.0 for X axis. So I don't loose steps at all for signal part. I also tried to lower acceleration to 2mm/s^2 just to make sure that acceleration is not the problem. I also tried to lower speed. I always lose steps with this code in attachment.
    I use driver DM556, and power supply SW-13A-36V. Stepper motor is NEMA 23, 57HS112 (3A and 3Nm).
    I don't have any idea left, so if someone have any suggestion, please free to replay. Thank you in advance
    Re: Step motor losing steps - no load
    Try setting the microsteps to 1/8 or 1/10 (1600-2000 steps/rev). If you are getting resonance, this should help.
    Also, when a motor is not mounted to anything, it's more susceptible to resonance, so it may actually be worse when it's not on the machine.
    What control are you using?
    Mar 2012
    7
    I will try that, I tried allready 1/4 also but its same. I use mach3.
    Wont i get a lot less power with 1/10?
    Nov 2012
    1267
    Is your STEP signal polarity correct? Try inverting it (in Mach3 "Ports and pins" menu) and see what happens.
  1. Stepper Motor Driver DQ542MA losing steps
    By kunte in forum Stepper Motors / Drives
    Last Post: 09-25-2015, 10:17 PM
  2. stepper motor losing steps and stall
    By animalza in forum Stepper Motors / Drives
    Last Post: 05-04-2015, 06:59 PM
  3. Step motor stall& missing steps at speed higher than 50ipm
    By mrbigde in forum Stepper Motors / Drives
    Last Post: 06-05-2014, 01:01 AM
  4. 12 tooth pinion direct drive 1/8 micro step Whats my steps per inch???? motor tuning
    By greenjeens in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-26-2013, 01:50 PM
  5. How quickly can a stepper motor be started without losing steps?
    By Robotics Guy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-07-2010, 03:12 AM
