can i have a copy of your cheat sheet [email protected]
Your post is dated 2003. If it is still available I would like a copy of your cheat sheet on canned cycles, particularly G76.
Thank you,
MIchael
May I have a full copy of your cheat sheets please, [email protected][,QUOTE=dcrace;326166]G0X__Z__(approach Point
G76P_Q_R_
G76X_Z_R_P_Q_F_
First G76 Line Info
G76 P010060 Q00500 R.001 (finish Passes)
G76 P010060 Q00500 R.001 (chamfer Amount At End Of Thread)
G76 P010060 Q00500 R.001 (tool Tip Angle)
G76 P010060 Q0050 R.001 (minimum Depth Of Cut - Radial Value)
G76 P010060 Q0050 R.001 (finishing Pass Depth)
Second G76 Line Info
G76 X Z R P Q F (minor Dia Of Male)(major Dia Of Female)
G76 X Z R P Q F (end Point Z)
G76 X Z R P Q F (radial Diff. Of Tapered Thread)
G76 X Z R P Q F (height Of Thread - Radial Value)
G76 X Z R P Q F (first Depth Of Cut - Radial Value)
G76 X Z R P Q F (feedrate / Pitch)
***R Value Can Be Omitted If Cutting A Straight Thread***
EXAMPLE CODE FOR 1/2-13 THREAD, WOULD BE AS FOLLOWS:
(TURN ON SPINDLE, CALL UP TOOL, TURN ON COOLANT HERE)
G0X.6Z.2
G76P020060Q0050R.0005
G76G76X.404Z1.0P0100Q0472F.0769
This is part of a "cheat sheet" of lathe canned cycles I made up to help train new setup people. If anyone is interested, I can e-mail it to you in excel format.[/QUOTE]
[/QUOTE]
Could I get a copy of your "cheat sheet"
[email protected]
FANUC G76 THREADING CYCLE G76 FANUC THREADING CYCLE CNC PROGRAM WITH DESCRIPTION - CNC PROGRAMMING TUTORIAL
N10 M06 T01 01 ;
N20 M04 G97 S1000 ;
N30 G00 X45 Z5 ;
N40 G76 P020060 Q100 R50 ;
N50 G76 X38.7 Z-50 P1227 Q100 F2 ;
N60 G00 X45 Z5 ;
N70 M05 M09 M30 ;
DESCRIPTION OF MAIN PROGRAM :-
N10- Tool change command , select tool no. 1
N20- Spindle ON anti clockwise , constant spindle speed command , speed is 1000 rpm
N30- Rapid action command where X45 and Z5 .
N40- Threading cycle command , P020060
( P02 = No. of finished path
00 = Chamfer amount at end
60 = Angle of tool tip ) ,
Q100 = Each cut is 0.1 mm ,
R20 = finishing allowance 0.02mm
N50- Threading cycle command , Minor dia X axis , threading along Z- axis up to -50 , Threading depth , Depth of finish cut 0.1 mm , pitch is 2 .
: M40X2
Major diameter is 40
Pitch is 2
Thread depth calculation = Pitch x 0.61363
= 2 x 0.61363
= 1.227 mm in micron is 1227
Minor diameter = 40-1.23 = 38.7 mm
N60- Rapid action command where X45 and Z5 .
N70- Spindle off , coolant off , main program end .
FOR MORE INFO VISIT - CNC PROGRAMMING TUTORIAL
For detailed information on threading, G32. G34, G76 and G92, may have a look at this.
G76 FANUC TAPER THREADING CYCLE EXAMPLE - CNC PROGRAMMING TUTORIAL
01542
N10 M06 T03 03 ;
N20 M04 G97 S1000 ;
N30 M08 ;
N40 G00 X50 Z2 ;
N50 G76 P010060 Q100 R50 ;
N60 G76 X45 Z-55 P1227 Q200 R10.5 F2 ;
N70 G00 X50 Z2 ;
N80 M05 M09 M30 ;
DESCRIPTION OF PROGRAM :-
Starting calculation please click here
01421- Name of program
N10- Tool change command , select tool no. 3
N30- Coolant ON
N20- Spindle ON anti-clockwise ( for RH thread) , constant speed command , speed is 1000 rpm
N40- Rapid action command , where X50 and Z2
N50- Threading cycle command , P01 - no of finish path
00 - chamfer amount is 00mm
60- angle of tool tip ,
Q100- each cut is 0.1 mm ,
R20- finishing allowance 0.02 mm
N60- Threading cycle command , X45 is end diameter , tool threading upto -55 in Z axis , P thread depth 1.227mm , depth of finish cut is 0.2 mm , R taper thread parameter is 10.5 , F is pitch is 2.
P Depth of thread = pitch x 0.6136 = 2 X 0.6136 = 1.227 mm = 1227 in micron
R taper thread parameter = ( end dia. - start dia ) / 2 = (45-24) / 2 = 10.5
N70- Rapid action command , where X50 and Z2
N80- Spindle OFF , coolant OFF , main prog. end .
for more visit ---- CNC PROGRAMMING TUTORIAL
