586,069 active members*
3,445 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > VK 45 II NUMC BOARD ERROR
    Hello,
    I am having a problem with my VK 45 II with seicos M3 controller. It started a couple of weeks ago showing randomly NUMC board error on a daily basis both when the machine was running a part or on standby. This made the machine go on e stop.
    Starting today when ever I press MDY button on the panel the error appears :NUMC SYSTEM FAIL, Software error occurs in the NUMC board . All the other machine functions and buttons work ok, but I can't start a program in memory mode.
    The machine data and parameters are ok, I even scrolled trough the ladder diagram to check for changes but nothing. When the error occurs there are 2 red led s on the NUMC board number 3 and 5.
    Thank you
    Dec 2009
    539
    Re: VK 45 II NUMC BOARD ERROR
    Hello
    the NUMC is failing based on what you are describing (and what the controller is telling you). This is a common fail-point within the SIII controller. Best thing is to backup you NC now;
    LED3 is FAIL and LED 5 is SOFTALM
    If you need further assistance please PM me and I will help; there is a process that needs to be done before swapping parts
    Its also possible the NUMC software is failing that is on the EPROM ( I have seen it only once or twice in my experience) but its a possibility.
    John
    Mar 2006
    34
    Hello John,
    Hitachi Seiki periodic alarm 1107 occurring in the Seicos M3 indicating NUMC System Fail - CPU HLT occurs in the system board. Is it worth reseating the board and retrying thanks? If so, I would have to back up as mentioned above, I think you mentioned that there is a procedure. regards Dave
    Apr 2014
    4
    Did you find a resolution to the NUMC fail
  1. USBIO:Board malfunction. unrecoverable IO error
    By jeffrey001 in forum Tormach PathPilot™
    Last Post: 01-12-2019, 07:12 PM
  2. OKUMA SVP board: 1-1 CPU Alarm bus error
    By robodo in forum Okuma
    Last Post: 11-13-2017, 10:32 AM
  3. Fanuc 10TE-F with main board error F
    By superstardeejay in forum Fanuc
    Last Post: 10-24-2017, 09:48 AM
  4. 8055 axis board error 2012
    By pazdersk in forum Fagor Automation
    Last Post: 06-12-2009, 09:36 PM
  5. R2E4 SFP Board error
    By arsenix in forum Bridgeport / Hardinge Mills
    Last Post: 08-06-2008, 07:08 PM
