586,068 active members*
4,091 visitors online*
    Why is my Rack & Pinion so noizy?
    Hi guys, my first post here.
    Just finished building this cnc plasma structure. Trying to get it dialed in.
    I have nema 23 motors and rack and pinion.
    Why is it so damn noisy?
    It sounds like a vacuum cleaner with a bunch of rocks tumbling around in it.
    I ended up sanding the 2x2's to make them smoother but it barely helped.
    Its not nearly as loud in the video... but you get the point.
    Everyone else's machines sound so cool, like electric cars and mine sounds like rocks in a tin can?
    thanks!
    https://www.youtube.com/watch?v=uTRC...ature=youtu.be
    Dec 2013
    5717
    Re: Why is my Rack & Pinion so noizy?
    It really sounds like the steppers are running a bit rough for some reason. Or it could be that your pinions are set a bit deep into the rack.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2020
    4
    Is the gantry running smooth still though? It sounds like something is loose to me. Maybe even just a screw that is vibrating around.
    Nov 2020
    hello everyone i'm new in this forum.
    i've build router table 150cmx200cm. i'm use nema 23 for X & Z axis.
    for Y axis i using dual nema 34 rack&pinion,without reducer& spring .size pinion (D 40.5mm 25teeth from amazon)
    .i'm use metal UNP for attach SBR16 rail & rack rail.
    i'm use mach3 usb
    i have a question,
    which is better to attaching rack rail on above or bottom side? what it's pros and cons ?
    thankyou verymuch
    please i need help&explained..
    Dec 2013
    5717
    You normally want the rack teeth pointing down so that it doesn't fill up with chips and crud. Gravity is your friend here.
    Jim Dawson
    Sandy, Oregon, USA
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. Replies: 3
    Last Post: 05-05-2015, 04:16 PM
  3. Ballscrews or rack and pinion? What module of rack and pinion is the best?
    By masinecc in forum DIY CNC Router Table Machines
    Last Post: 04-13-2015, 06:04 PM
  4. dual pinion rack and pinion anti backlash
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-12-2011, 04:04 AM
  5. Rack and Pinion- rack tensioned to pinion?
    By Rees Guitars in forum Linear and Rotary Motion
    Last Post: 05-09-2011, 06:05 PM
