586,075 active members*
3,984 visitors online*
    Oct 2005
    1145
    ADD B axis to PathPilot
    I am working to add a new axis (B) to PathPilot . I have copied over what I think is everything to teh HAL and INI. BUT I get an error on load
    HAL: ERROR: function 'pid.4.do-pid-calcs' not found
    I am not sure exactly what it means. That line is on line 70 of the hal and the Pid 4 does exist and the PID data is in the INI file under axis_4.
    Any Ideas on where to look next ???
    (;-) TP
    May 2013
    49
    Re: ADD B axis to PathPilot
    This is a shot in the dark:
    For example if your config already has 3 pid loops for controlling your axis and you want to add a 4th one.
    Change the line:
    loadrt pid num_chan=3
    to
    loadrt pid num_chan=4
    It will not work to have two lines (even it they are in different hal files.)
    loadrt pid num_chan=1
    I found the above info from the linuxcnc forum
    Oct 2005
    1145
    AH that was it. I would never have found that. ThankYou
    I now have B axis motion but no screen support yet. I will TRY to add it into the toolpath window up in the top left hand corner.
    It will be used to drive an ATC. https://www.dropbox.com/s/62opkiumhv..._3165.MOV?dl=0
    IF you did not know the BP hd a tool changer you would not notice it until it popped out and unfolded and went to work. Tools stay super clean.
    (;-) TP
    Oct 2005
    1145
    Well B axis worked out BUT C sure did not (;-) I copied everything over to c and made all teh changes and NODDA. PP looks like it should be working but doesn't move C.
    It is never easy (;-) TP
    Oct 2005
    1145
    OK I found that sorry little copper head rattle moccasin problem child. Now I have a usefull B and C axis that is NOT linked into the toolpath. They will be used to run a dual arm 24 tool look ahead ATC with PathPilot in control.
    Now I just need to figure out HOW to place a set of DROs in teh toolpath window . PP has some things there already I just need to figure out how they did it.
    (;-) TP
  1. B and C axis with PathPilot
    By vmax549 in forum Tormach PathPilot™
    Last Post: 05-30-2020, 01:40 PM
  2. PathPilot 2.x and PathPilot Simulator
    By draper-ballou in forum Tormach PathPilot™
    Last Post: 01-01-2019, 01:42 AM
  3. Replies: 2
    Last Post: 12-03-2017, 12:02 AM
  4. PCNC770 4th Axis with Clear Path Servo and PathPilot
    By charliebrumfield in forum Tormach Personal CNC Mill
    Last Post: 10-07-2017, 12:09 AM
  5. PathPilot 5 Axis Support/Capabilties
    By zach540 in forum Tormach PathPilot™
    Last Post: 05-11-2017, 04:24 AM
