586,117 active members*
3,488 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Do double ballnut diy setup increases Dynamic and Static Rating load?
    Mar 2016
    68
    Hi!
    If I do a double ballnut setup (using two single ballnuts) , back to back, does it changes the dynamic and static load properties of a single ballnut/ballscrew system?
    What happens physically (or practically) to a double ballnut diy system, besides reducing backlash? Increases wear? Makes it more... stiff, rigid?
    Thanks!!
    Jun 2013
    443
    Re: Do double ballnut diy setup increases Dynamic and Static Rating load?
    I put a double ballnut on my Z driving a spindle double the weight. But it wasn't two back to back, it was one with the mounting flange connected to a nut without the flange. Connected by two strips of 1.2mm steel.
    It was most certainly more difficult to rotate. Had absolutely no backlash. Took 50mm of travel out of my Z. But I am pleased I put it there.
    My view is anything you can do to increase or improve a diy machine has to be good.
    Sent from my SM-N970F using Tapatalk
    Jul 2020
    I suppose double ballnut is often used on Z axis because it usually holds heavy static/dynamic load on its shoulders. Double count of balls means double ground contact and half of pressure per ball. Please correct me if I'm wrong.
  1. Load Rating
    By kolias in forum Open Source CNC Machine Designs
    Last Post: 03-10-2012, 06:52 AM
  2. Static and Dynamic Load Capacity of Linear Ball Bearings
    By traynhamdv in forum Linear and Rotary Motion
    Last Post: 06-12-2011, 04:58 PM
  3. newbie don't know his load rating pls help
    By 15mgtar in forum Mechanical Calculations/Engineering Design
    Last Post: 09-07-2009, 03:27 PM
  4. calculating a rough estimate for bearing dynamic/static load
    By margni74 in forum Linear and Rotary Motion
    Last Post: 08-21-2007, 04:20 AM
  5. static & dynamic load ?
    By mdreitzusa in forum Mechanical Calculations/Engineering Design
    Last Post: 12-13-2005, 12:03 PM
