586,103 active members*
3,662 visitors online*
Thread: Tool holder
    May 2013
    22
    Tool holder
    Can you just use a round pocket for a tool holder or does the standard holder help pull out the tool, BT30? Going strait down into the holder saves space and avoids conflicts with the dust boot. Thanks for the help, Edward
    May 2013
    22
    Re: Tool holder
    I see that these are properly called tool forks not tool holders.
    Nov 2012
    1267
    Re: Tool holder
    The fork does not pull the tool out, the tool drops free when the spindle releases it. A straight down hole would probably work, but:
    1. You need to have some spring action so the tool could spring down 1-2mm.
    2. You need to have some breakaway parts in case something goes wrong during the tool change. A broken plastic fork is no big deal, a broken spindle is a disaster.
    Aug 2009
    1573
    Re: Tool holder
    ...aka Tool Gripper? :Claw, Fingers, Chop Sticks....
  1. Replies: 0
    Last Post: 01-18-2019, 09:00 PM
  2. HSK Style Tool Holder Manual Tool Change Spindles
    By tinmancarving in forum Spindles / VFD
    Last Post: 10-01-2018, 08:05 PM
  3. Bridgeport boss 6 quick change tool holder not holding tool properly.
    By TBCind in forum Bridgeport / Hardinge Mills
    Last Post: 04-04-2017, 06:56 PM
  4. Vertical lathe tool holder for Tormach Tool System.
    By TXFred in forum News Announcements
    Last Post: 08-18-2014, 09:20 AM
  5. Replies: 10
    Last Post: 11-06-2012, 11:43 PM
