586,060 active members*
4,521 visitors online*
    Turret Sensor not work
    need help!
    pls help. My cnc Machine Turret Sensor not work. so how i remove it and replace it.
    May 2016
    526
    Re: Turret Sensor not work
    Would be handy if you gave more information such as machine type and turret
    Quote Originally Posted by akterhossain View Post
    need help!
    Is it 14/15T hall sensor in the four position turret?
    If yes, then replace a new sensor could solve the problem.
    Or if you are using it with Fanuc controller, you might need to add pull-up resistors.
    You can refer to below page for similar issue.
    14/15T Sensor for Fanuc Control
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  1. Alarm 221 (Turret Sensor Malfunction)
    By motif in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-15-2022, 01:21 PM
  2. QT 20 T plus, alarm 220 Turret position sensor malf.
    By mantenim in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-18-2016, 10:27 PM
  3. Turret proximity sensor adjustment
    By MichaelHenry in forum Tormach Slant Lathe
    Last Post: 06-06-2016, 12:24 AM
  4. Sensor for Lathe Tool Turret
    By kNucklBustr in forum Mini Lathe
    Last Post: 07-15-2013, 02:44 PM
  5. turret clamp sensor malfunction
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-03-2007, 05:47 AM
