586,061 active members*
4,540 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Dec 2019
    5
    Re: MPG Pendant update and issue
    Thanks for the reply.
    I did figure the problem out though thanks to this forum.
    It turns out that the setup instructions provided with the usbmach board tells you to not assign pins to the mpg and thats the whole problem if you are not using an mpg thats goes thru usb.
    What I did was assign pin 10 port 1 to estop, and the mpg i assigned pin 12,13,14 and 15 on port 1 and low and behold it works as intended.
  2. #22
    Mar 2008
    Hello guys,
    I write here, because have almost the same issue with my new MPG (Handwheel) .
    I try to connect it to DDCS Expert, but the behavior is not what should be.
    Instead of rising or lowering the values by the choosen axis, the values jumping up/down randomly.
    I've measured the outputs A+ B+ A- B- and received really NOT rectangle pulses.
    Attachment 500848Attachment 500850
    https://youtube.com/shorts/T-SgroRFO7Y
    What is yours opinion: are this pulses OK and have to search for another issue or have to buy a new handwheel?
Page 2 of 2 12
  1. BlueProbe issue-update Mach3?
    By RIZ/co. in forum Mach Mill
    Last Post: 02-13-2019, 10:29 PM
  2. Issue with UCCNC HW and VistaCNC P4-SE pendant
    By ronsand in forum UCCNC Control Software
    Last Post: 02-12-2018, 09:08 AM
  3. issue with chamfer in update 996 v25?
    By Big Chips in forum BobCad-Cam
    Last Post: 06-11-2013, 03:45 PM
  4. Update to -5 now rigid tapping issue
    By carbidecraters in forum Fadal
    Last Post: 02-15-2011, 06:36 PM
  5. pc2100 pendant issue?
    By mystic1582 in forum Tree
    Last Post: 02-07-2009, 12:40 AM
