Re: Powering CNC from two different outlets?
Originally Posted by
PrestonH
Interesting. Also, I was thinking about ground loops
There is a current practice now called equi-potential bonding, this is in order to reduce or eliminate earth GND loops etc, this is to GND all metalic parts of the machine and enclosure.
Siemens Electric published a paper on this subject that explains it in detail, including the ability to ground both ends of shielded cables now when using the equi-potential bonding method.
Also there are two schools of thought regarding earth bonding all electrical power systems, one is to keep all systems separate and isolated from each other, the other, which I have always subscribed to, is to earth GND one side of all power supplies etc.
Both AC and DC, this is often done in industrial package systems where one purchases a pre-made system, rather than most DIY systems that are made up from different modules and units etc.
This grounding has tended to eliminate many such things such as spurious tripping of limit inputs etc by those posting here with the issue..
Your desk top PC has this built into its DC supply already, i.e. service grounded through the P.S. common via the MOBO ground plane.
I have used this methodology throughout my career without experiencing any ground nuisance faults.
BTW a ground loop is defined as a condition where a potential exists between various points on a ground plane in a earth bonded system.
Al.
Albert E.
