586,112 active members*
2,999 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > help - where can i buy timing belt pulleys for a Vectrax upgrade
    Feb 2007
    41
    I'm upgrading an older Vectrax cnc Big Bridgeport style mill.
    I bought the Nema 42 kit from AutomationTechnologies.
    Nema 42 motors are 3/4" bore. and the original pulleys are smaller.
    I have L belts and pulleys 3/4 wide by .375 pitch but i need to replace the motor pulleys.
    Who do you recommend ?
    Dec 2013
    5717
    Re: help - where can i buy timing belt pulleys for a Vectrax upgrade
    Last time I needed to replace motors I just bored the pulleys to fit the new motors.
    Or a good option is Ametric https://www.ametric.com/
    Mcmaster Carr https://www.mcmaster.com/timing-belt-pulleys
    Automation Direct https://www.automationdirect.com/adc...ts_-a-_pulleys)
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2007
    41
    Quote Originally Posted by GUIDOSAN View Post
    thanks for the leads - I did rebore one , one is damaged
    I really appreciate the reply
    15362
    3/4 wide seems a little light for that size machine the old Bridgeport CNC machines use 1"wide H section Timing Pulleys and Belts
    Here is a good supply also
    https://www.brecoflex.com/products/t...elts/t-series/
    Mactec54
  1. Timing/Belt pulleys...source?
    By millerized in forum Avid CNC
    Last Post: 05-03-2017, 04:47 PM
  2. How to match Timing pulleys and timing belt? (noob question)
    By cdesantis01 in forum Linear and Rotary Motion
    Last Post: 02-10-2017, 01:27 AM
  3. Making my own timing belt pulleys - how?
    By damae in forum MetalWork Discussion
    Last Post: 08-01-2010, 04:51 PM
  4. Timing belt and pulleys
    By samakthachai in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-25-2007, 05:31 AM
