587,008 active members*
3,547 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > threadmilling on a hardinge vmc600 need help
Results 1 to 5 of 5
    Nov 2012
    68
    I'm trying to threadmill on our old hardinge vmc600 for the first time and having issues. Fanuc control.
    1/2-14 NPT
    304ss
    1/2 dia threadmill solid carbide 4 flute tapered
    I've tried a generated g-code from the guhring website and it gives me a 041 cutter comp alarm
    The program is using incremental, drops the threadmill in, turns comp on with a g3 move, then spirals out.
    I've never done any threadmilling before but really want to, especially for this tough pipe thread in 304ss.
    Can anyone give me some tips. We don't have cad/cam, I write all our programs.
    Feb 2011
    353
    Re: threadmilling on a hardinge vmc600 need help
    I have found that most of the cnc's that i have run they want to use a G1 move to set the comp and don't like to set the cutter comp with a G3 move
    post your code so that it can be looked at
    Nov 2012
    68
    Thanks for the tip, I'll post the code when I have time at work today.
    Hi. I don't know how useful this will be for you but I have attached some photos of a program I wrote myself to do thread milling, its in Hiedenhain though.
    Q3 is the X position
    Q6 is the Y position
    Q0 is the diameter of the thread divided by 2
    Q7 is the feed
    Q9 is the depth
    LBL 1 positions the cutter, puts it down the hole and engages the cutter with the job whilst applying cutter compensation.
    LBL 71 circles the cutter 360degrees whilst incrementally moving the Z axis up by the required pitch.
    I do hope this helps and is understandable. You can ask questions should you have any.
    Regards. Steve.
    I managed to post the pictures back to front, but obviously the program reads from line 3 to line 22.
  1. Bridgeport VMC600/22 buffer batteries
    By HugoLargo in forum Bridgeport / Hardinge Mills
    Last Post: 12-04-2018, 03:16 PM
  2. hardinge VMC600 programming issue when using R-word insert arc
    By joeyjrc in forum Bridgeport / Hardinge Mills
    Last Post: 11-18-2016, 03:40 PM
  3. Replies: 0
    Last Post: 01-07-2012, 04:17 PM
  4. Bridgeport VMC600/22
    By de_firma in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2011, 11:50 AM
  5. VMC600 table removal
    By smellyfeet in forum Bridgeport / Hardinge Mills
    Last Post: 10-24-2011, 02:16 PM
