586,036 active members*
3,576 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Connecting 2 different spindles/vfd to one BOB
Results 1 to 6 of 6
    Sep 2019
    44
    Hello,
    I would like to use a second spindle on my dual z setup instead ot the spindle/router setup i have now.
    The problem is i don't know howto approach the connection of the second spindle onto the BOB.
    On the BOB(avid cnc/cncrp) i only have one spindle relay and one 0/10v vfd steering.
    Both spindles are different :
    spindle 1 max freq of 400hz / 1x220v
    spindle 2 max freq of 300hz / 3x220v
    Any help would be apreciated!
    Stay safe,
    Adam
    Sep 2019
    44
    Re: Connecting 2 different spindles/vfd to one BOB
    Nobody that can send me in the right direction?
    15362
    Quote Originally Posted by DAAD View Post
    You just need to add another spindle control board does not matter if the spindles are different the control side does not change only the parameters set in the VFD Drive
    An add on board like this will do the job or any other similar one's
    Mactec54
    Sep 2019
    44
    thanks for the input!
    After talking with a friend who is an electronic engineer, he suggested to work with 2 relay's to swith the on/off and the 1/10V signal with another output signal.
    I've ordered an 8 relay SPDT and will try it this way first.
    Keep safe,
    Adam
    15362
    Keep safe,
    Adam
    I though you wanted to run both spindles at the same time, if so you can't do that with just switching the same outputs
    Mactec54
    Sep 2019
    44
    Both spindles do not run at the same time, but serve as a "toolchanger" with 2 tools
    At the moment i'm using a relay to switch contact between spindle on and router on. I suppose it would be possible to "swap" the 0-10 V signal also.
    In mach 4 i think i can setup a second spindle with different configs?
    There will be some programming needed.
  1. Why are keling ATC spindles so much more expensive than er11 spindles?
    By sburck in forum Automation Technology Products
    Last Post: 12-20-2019, 02:32 PM
  2. MB 521 not connecting to TNC 320
    By stttiger in forum HEIDENHAIN -> TNC
    Last Post: 06-07-2018, 10:42 PM
  3. Any reasonably priced (cheap) spindles other than the chinese spindles?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 11-05-2014, 11:16 PM
  4. Spindles de alta qualidade.High quality spindles.
    By Newtron in forum News Announcements
    Last Post: 09-21-2009, 08:33 PM
  5. connecting
    By KrashKing405 in forum Open Source Controller Boards
    Last Post: 07-26-2006, 11:30 PM
