586,075 active members*
4,087 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > I'm Going Closed Loopy (Nema 34 Hybrid + HB860H encoder issue)
Results 1 to 8 of 8
    Feb 2016
    Hey guys, first post for me here. Longtime lurker on the forum and most of my questions are usually answered with a quick use of the search bar but I'm finally stuck and I need help.
    Problem: 12Nm Closed Loop Stepper and HB860H driver won't function with Encoder mode enabled, but will function normally with encoder disabled.
    With encoder disabled (Switch 6 ON) the motor runs as commanded proving that the issue is not motor phase wiring related.
    With the encoder mode enabled (DIP Switch 6 set to OFF) and given a jog command, motor whines faintly but doesn't move, then bumps a couple steps and then the driver goes into Alarm mode.
    With the encoder enabled but the encoder wires disconnected from the driver the motor does the exact same thing, same noise, bumps a couple steps and alarms.
    I've spent several hours pouring over the wiring and checking continuity and correct pin-outs on the encoder cabling, it's all correct. The encoder is getting 5V from the driver like it should. I even tried going from "differential" to "single end" step and direction wiring configuration to the driver to see if it liked that better for some reason...nope.
    I tried reversing encoder phases, reversing motor phases, changing microstep settings... nothing has worked.
    Running:
    - Mach4
    - ESS and MB2 board
    - 5mm Ballscrew, 1600 Steps/Rev, 8128 pulses/inch in Mach4
    - Commanding a very conservative 100in/min with 5in/sec^2 acccel.
    Here's the exact motor and driver https://www.aliexpress.com/item/3283...42734c4dK1tOKp
    Thanks for any help in advance!
    This is for the Z axis on my EG Mill I built.
    https://www.cnczone.com/forums/attac...d=452446&stc=1
    ~ Owen
    Re: I'm Going Closed Loopy (Nema 34 Hybrid + HB860H encoder issue)
    I hope you have solved problem a long time ago and successfully. But, just in case, its in the wrong encoder connection. We have already purchased the item from this seller - and it is not documented. On the Internet, the colors of the wires for the encoder are indicated - in our case they are connected differently. Change yellow with black (A- A +) and it is likely that your problem will be resolved
    Ops. I was mistaken, yellow with black I changed in another device
    well working order,
    left to right: white, red, black, brown, green, yellow
    Dec 2015
    10
    Hi everybody, I have a similar issue with 12Nm hybrid and HBS860H.
    The motor runs for few steps with noise, then red light on the driver flash. Can anybody help me?
    https://www.cnczone.com/forums/attac...d=461458&stc=1https://www.cnczone.com/forums/attac...d=461460&stc=1https://www.cnczone.com/forums/attac...d=461462&stc=1https://www.cnczone.com/forums/attac...d=461464&stc=1
    Dec 2015
    10
    I just want to give a contribute telling who has the same problem that I have solved looking at the encoder wires colors.... there were an error in the sequence....To understand that, I have taken out the encoder cover and looked at sequence.
    May 2022
    Hello @trivalb,
    I think I've encountered the same problem.
    In your pictures the wiring seems to correspond to what is mentioned on the sticker on the motor.
    Are you saying this is wrong? That the encoder wire colors mentioned on the sticker on the motor are wrong?
    And we need to open the motor to figure out the correct colors?
    May 2022
    If anyone stumbles on this thread with the same problem: I opened the motor and found that the sticker corresponds to the wire colors.
    I finally got it working by:
    1. Checking all connections
    2. In the encoder wires: switch A+ with B+ AND A- with B-
    (So different from what the sticker on the motor says).
    - - - Updated - - -
  1. hybrid Closed Loop Stepper vs dmm servo
    By rmachinist in forum Benchtop Machines
    Last Post: 11-21-2019, 05:12 AM
  2. Closed loop hybrid stepper motors.
    By heavyweather in forum Stepper Motors / Drives
    Last Post: 11-03-2018, 01:51 AM
  3. NEMA 23 Closed Loop Stepper Motor System-Hybrid Servo Kit
    By automationtechinc in forum Automation Technology Products
    Last Post: 07-22-2018, 05:53 PM
  4. Replies: 0
    Last Post: 05-06-2015, 01:11 PM
  5. Converting Nema 23 motor to hybrid with encoder?
    By Goose80 in forum Stepper Motors / Drives
    Last Post: 11-07-2014, 08:40 AM
