586,655 active members*
2,342 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > 1996 TC22 with dx32 controller C-axis problem
    Exclamation 1996 TC22 with dx32 controller C-axis problem
    Our company just bought another TC22 (we now own 3) but this new machine is having a couple issues. When you turn the machine on once it loads DOS and enters the screen to enable drives and home all axis it shows the C-axis as homing but it locks on that and shows a feed of 406ipm but there is no 4th axis installed on the machine and it will continue to say (wait homing) till it is shut down. To explain the is no power supply or driver for the 4th axis. We have ruled out faulty signal from the axis plug. I removed the (a-axis installed)(wires 220 and 221) connector from the AUF board and same thing happens. so any help would greatly be appreciated.
    Thank you. TheTurnGuy
    Jun 2011
    152
    Re: 1996 TC22 with dx32 controller C-axis problem
    Quote Originally Posted by TheTurnGuy View Post
    Maybe check your parameters? I don't remember is there is a setting that enables the 4th axis. I know there is homing stuff for the other 3 axis.
    Richard
    Jan 2018
    44
    Not that I have an answer for you but what controller is on that machine?
  1. Z axis problem on 1996 sabre 1000
    By ROSSITERENG in forum Cincinnati CNC
    Last Post: 04-14-2016, 05:27 PM
  2. problem with 1996 fadal 4020
    By Molderone in forum Community Club House
    Last Post: 01-28-2014, 03:17 PM
  3. DX32 Controller Software Install Options???
    By Cellar Dweller in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2012, 11:35 PM
  4. Bridgeport Torq-Cut 22 with DX32 controller
    By murad in forum Bridgeport / Hardinge Mills
    Last Post: 08-18-2009, 10:46 AM
  5. B'port tc22 / dx32 alarms
    By edspert in forum Bridgeport / Hardinge Mills
    Last Post: 10-22-2006, 04:32 AM
