586,357 active members*
3,724 visitors online*
    beisse editor
    hi all
    i work in a kitchen company and we've just started using the 12mm to 20mm thick concrete worktops (compressed paper i think) what i'm trying to do is create a panel for a kidney shaped sink cut out approx size 500mm - 400mm and then save it so i can import it on to a different panel say 600mm - 2400mm in a set position
    any help would be appreciated
    mark
    Nov 2011
    21
    Re: beisse editor
    Hi Mark, you can save that program with cut as subprogram (into folder p_p/sprog/) and call it from any program by instruction L=subprogram_name .
    Apr 2018
    37
    Re: beisse editor
    You could also create the machining as a macro and then it'll be saved into it's own little tab on the right hand side under the Macros. Then it'll be a case of changing the variables.
    Nov 2011
    21
    Re: beisse editor
    Yes, thats possibility if you have Biesse works editor.
  1. Beisse Rover 321R
    By MCMJoinery in forum Questions or Problems
    Last Post: 03-18-2019, 12:16 PM
  2. How to use multiple spindles in the same program? 346 Beisse Rover
    By ThePackofTrim in forum CNC Machining Centers
    Last Post: 10-08-2015, 05:15 AM
  3. beisse 346 cheap parts
    By peterklos in forum CNC Machining Centers
    Last Post: 10-15-2010, 01:40 AM
  4. MC X Editor
    By cijunet in forum Mastercam
    Last Post: 02-21-2008, 05:28 PM
