586,071 active members*
3,897 visitors online*
    Locking for Heidenhain rotary encoder.
    Hello,
    I am searching for a Heidenhain ROD 462.018 1024 / S.NR.3 709 545 B / L4 rotary encoder.
    Thank you
    Sep 2009
    99
    Re: Locking for Heidenhain rotary encoder.
    I think what you are looking for is a ROD 426. These are available on ebay. Otherwise you can find an equivalent from makes such as Kubler if you can't find this. Heidenhain too, still supplies these or a newer replacement but delivery times are usually longer.
    Best regards
    JSS
    Dec 2011
    99
    Id.:242079-01
    successor type Id.:376846-9U
  1. Locking for Heidenhain rotary encoder.
    By viorel23cnc in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-11-2020, 05:46 PM
  2. Manually adjustable locking rotary axis
    By cncbcncb in forum Wood Lathes / Mills
    Last Post: 12-26-2015, 01:42 PM
  3. Manually adjustable locking rotary axis
    By cncbcncb in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-25-2015, 06:20 AM
  4. Adding a rotary encoder to a large Rotary Table
    By small.planes in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2012, 07:27 PM
  5. Use of TTL rotary encoder instead of 11uA heidenhain
    By wahidbashir in forum Bridgeport / Hardinge Mills
    Last Post: 12-06-2010, 06:42 PM
