Originally Posted by
TomKerekes
I don't understand what you mean. But if you are moving at some speed you can look at what the Output is to move at that speed. Then for the Integrator to be able to provide that Output the Limit should be set greater than that value. The Integrator should also be increased if you are using D Gain as it acts as drag that the Integrator must also be able to overcome. If the Limit is set too low the axis will lag behind with negative error that will be needed to provide the output to move at speed. So if the axis is lagging behind for a long time, and the Output is not being ramped up to try to catch up, then that is an indication the Integrator is not working. Its gain is either too small or it is being limited
