586,072 active members*
4,472 visitors online*
Results 1 to 6 of 6
    Nov 2015
    260
    Dialog bevor M3
    Hello.
    I would like a dialog box to appear when the spindle is started.
    For this I wrote the following in M3 Script.
    Code:
    (dlgname,Start From Selected Line, opt=1)
      (dlg,Click OK to continue, typ=label, x=20, w=250, color=0xffa500)
      (dlgshow)
    If I start a program, or enter M3 in the MDI, or an M3 command comes in the q-code, it works.
    But when I press the spindle start button, it doesn't work, it seems to me that this button switches the output pin directly.
    Nov 2015
    260
    Re: Dialog bevor M3
    Ok i found it. You can change it in the settings.
    Somehow I have the feeling that TNGv2 has a solution for everything, I'm just too stupid to find it.
    Mar 2017
    1312
    Re: Dialog bevor M3
    You are not stupid. It is our fault that some features are never found and/or used.
    Re: Dialog bevor M3
    Quote Originally Posted by tantemay View Post
    I'm just curious: what was the required option?
    Thanks in advance,
    Gerhard
    Nov 2015
    260
    Quote Originally Posted by gachrainer View Post
    Thanks in advance,
    Gerhard
    Have a look.
    Have a look.
    Thanks!
  1. Deckel FP4 Dialog 4
    By alfanul in forum Deckel / Dialog
    Last Post: 09-18-2011, 10:38 PM
  2. Dialog 112
    By samop0806 in forum Deckel / Dialog
    Last Post: 01-11-2010, 04:56 PM
  3. DECKEL DIALOG 11
    By sipa in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-26-2009, 10:01 PM
  4. DMC 100 with dialog 112
    By Bert10 in forum Uncategorised MetalWorking Machines
    Last Post: 08-21-2008, 07:00 PM
