586,061 active members*
4,673 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Looking for advice on options for cnc router with 4th axis
Results 1 to 2 of 2
    Nov 2020
    Hey!
    I'm hoping you find people can help me out, I'm still pretty fresh into the world of cnc.
    I'm in the market for a cnc router that I can connect a 4th axis to. I work with a lot of 3D printers and we're ready to start on some wood work but I'm having a tough time finding something that will do what I need. I've built an MPCNC and it works fine but my DIY 4th axis is... Not great.
    I've looked at some 4th axis kits online and am only finding Chinese versions on Amazon. Is that the way to go? I just don't want to spend $500+ on one to discover it was a bad idea.
    For the cnc it itself, I've looked at one's like the workbee but am not sure if it's what I'm after.
    Basically I need a machine that can route cylinders that are about 1-1.5 inches in diameter and about 15 inches long. If 15 is too long I can also get away with closer to 7.
    It would be nice if it can also do normal 3 axis as well without to much work, but I can use my MPCNC for that if needed.
    Currently my budget is about $3000 CAD, which unfortunately doesn't go super far. If it an be done within that, awesome, or if I need to set aside more for it I can work towards that too.
    I really appreciate any advice anyone can give. I'm pretty good at figuring things out but we're in the middle of the holiday rush and I just don't have a ton of time to be digging through tons of information.
    Thank you!
    Apr 2004
    5737
    Re: Looking for advice on options for cnc router with 4th axis
    I could sell you the 4th axis kit that goes with the Taig Mills we sell. It consists of a solidly-built rotary table with a 72-1 planetary gear that accepts a range of chucks, has a NEMA 23-frame motor attached, and comes with an adjustable tailstock. It could certainly handle cylinders the size you mention, assuming there's room on the bed of your MPCNC and a spare driver channel to run the motor.
    Andrew Werby
    Website
  1. Looking for advice re gear cutters for cnc router with 4th axis
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 05-28-2019, 01:23 PM
  2. Advice on replacement spindle options
    By Rabs2014 in forum Spindles / VFD
    Last Post: 05-30-2016, 08:36 PM
  3. would appreciate advice on manual x/y axis wood router
    By vjeko in forum Linear and Rotary Motion
    Last Post: 01-23-2014, 06:07 PM
  4. Gantry Options/advice
    By robe_uk in forum DIY CNC Router Table Machines
    Last Post: 02-01-2011, 08:38 PM
  5. AutoCad Upgrade advice/options..
    By hotponyshoes in forum Autodesk
    Last Post: 03-15-2006, 11:17 PM
