586,108 active members*
2,986 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Same Part Multiple fixtures?
Page 3 of 3 123
Results 41 to 58 of 58
  1. #41
    Aug 2007
    47
    Quote Originally Posted by Donkey Hotey View Post
    Yeah, it looks like you're going to need to post the file or send it directly to me. I can't look at it until tonight. PM me if you can't post it for whatever reason and need my email address.
    Yeah, looks like. I tried the tip above too to no avail.
    Here's the file.
    -Taylor
    Attached Files Attached Files
  2. #42
    Nov 2007
    1702
    It works on mine. I did a 2" translate, 4 copies, to the right and it posted:
    G54
    G55
    G56
    G57
    I saved it and reposted it here. See if it doesn't work now.
    Greg
  3. #43
    Jul 2005
    12177
    Maybe it will make you feel good to know that because of this thread when we met with the MasterCam guy recently I was able to ask questions that made it appear I knew far more than I really do about the multiple work zero output. I also was able to ask questions about things like trochoidal machining and face peeling.
    So you guys should feel thoroughly brain-picked.
    When we placed the order he asked my Production Manager how many MasterCam Tee-Shirts we wanted. The answer was that if we didn't want to play favorites it had to be none or sixteen so we could give one to each guy; so now we have sixteen $1,000 tee-shirts and they threw in two MasterCam seats as an extra.
    P.S. Haas Apps you owe me about 1200 Haas Tee-Shirts.
  4. #44
    Nov 2007
    1702
    That's good news, Geof. If I read enough of your posts, I might someday take "CNC nOOb" off of my signature line.
    Greg
  5. #45
    Jul 2005
    12177
    Should I post a picture of me in a MasterCam Tee-shirt?
  6. #46
    Jan 2006
    4396
    Quote Originally Posted by Geof View Post
    Only if it says Mastercam X4
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
  7. #47
    Aug 2007
    47
    G54
    G55
    G56
    G57
    Yeah, I'm really starting to think this is an issue with my Post, as that file doesn't do it for me. Grr... Are you using the generic HAAS 3 axis post or something else?
    -Taylor
  8. #48
    Nov 2007
    1702
    Yup, standard Haas post. What version of Mastercam are you running? I've made some minor tweaks to my post so I'm not sure if I'd be comfortable recommending it (I don't remember what I did--it's been awhile).
    You opened the file and didn't change anything, right? Are you SURE that it didn't create the extra work offsets? I'm assuming that you searched for G54 and found it multiple times. That's correct since it's going to do one operation at G54, then G55, G56, G57, then start over with the next op: G54, 55, 56, etc.
    Did you also search for G55, G56, etc?
    Greg
  9. #49
    Aug 2007
    47
    Yup, I found no G54, G55, etc in the posted file at all. I have also made some changes to my post I don't remember (trying to learn things and all), let me see if I can find my original unmodified machine definition and post and try posting with that.
    Thanks so much for helping!
    -Taylor
  10. #50
    Aug 2007
    47
    Hey sorry I haven't been back here, work has been busy and all.
    So I'll have to keep looking, I don't think I was able to locate my unmodified post so I'm not sure if my issue is the post or not. Do you mind sending me your post just so I can verify it's not something else? I know you said you don't recommend using it, I just want to make sure my post is the issue.
    -Taylor
    You can send it to my email at tlalexander <ignore this part> ~at~ gmail "dot" com
  11. #51
    Apr 2003
    3578
    facegarden, what version of Mastercam X are you running as this makes a difference on the post. I wanted to share but need exact version or the post wont work.
    Cadcam
  12. #52
    Aug 2007
    47
    I just have X1.
    -Taylor
  13. #53
    Aug 2007
    47
    So, it seems I can't get anything to post with multiple work coordinate systems.
    I've tried just making two drill points and setting each one to its own WCS, but when i post, it still just acts like I had set them both in the same WCS.
    Is that more likely in my post, or in my machine or control definitions?
    Attached is what I have under the "work system" tab in my control definitions, if that makes a difference.
    -Taylor
    Attached Thumbnails Attached Thumbnails Fullscreen capture 4232009 72848 PM.jpg
  14. #54
    Nov 2007
    1702
    Did you get my email? I sent you the post. Have you tried it?
    Greg
  15. #55
    Aug 2007
    47
    Ah! Sorry, i get so many e-mails that sometimes I miss things!
    Well turns out your post works!
    Furthermore, I was able to get my post to do it!
    We have slightly different functions for
    "pwcs #G54+ coordinate setting at toolchange"
    Yours is:
    Code:
            sav_frc_wcs = force_wcs
            if sub_level$, force_wcs = zero
            if workofs$ <> prv_workofs$ | (force_wcs & toolchng),
                  if workofs$ =  -1,workofs$ = 0
                  if workofs$ < 19, g_wcs = workofs$ + 54
              else, g_wcs = workofs$
                  if  (workofs$ > 5) & (workofs$ < 19), g_wcs = g_wcs +  50
                  if (g_wcs < 54) | ((g_wcs > 59) & (g_wcs < 110)) | (g_wcs > 122), pwcs_bad
              else, g_wcs
            force_wcs = sav_frc_wcs
            !workofs$
    Mine was:
    Code:
          if mi1$ > one,
              if workofs$ < 6,
              else,
                g_wcs = workofs$ + 104
              if workofs$ >= 0 & workofs$ <= 25, *g_wcs
              else,
                if mprint(swcserror, 2) = 2, exitpost$
            !workofs$
    I noticed mine had the "if mi1$ > one" condition. The rest of my WCS code seemed to be sensible, but yours didn't have that if statement. I wondered if my post was failing that IF condition and never setting the WCS, so i removed the if statement and everything works!
    I have no idea what that will do to other things, I am going to need to start looking into what all this stuff in the post means, but for the record and in case it wasn't clear, I ended up with that section of my post like so:
    Code:
              if workofs$ < 6,
              else,
              else,
            !workofs$
    The only real thing I noticed is that mine only allows 6 consecutive WCS's above G54 while yours allows 19, which my machine wouldn't support, I don't think.
    Anyway, anyone know what I deleted?
    Thanks!
    -Taylor
  16. #56
    Nov 2007
    1702
    Quote Originally Posted by facegarden View Post
    I don't know what year your machine is but you have G54-G59 for your first offsets, then you may have G110-G129 as well. I'm not sure when Haas introduced those extra work offsets.
    Greg
  17. #57
    Jul 2005
    12177
    .....then you may have G110-G129 as well. I'm not sure when Haas introduced those extra work offsets.
    These have been available at least from 2001.
  18. #58
    Jul 2012
    62
    Donkey Hotey,
    Thanks for your posting on 10-25-2008, 10:41 PM. This was exactly what I was looking for. Your old posting really helped me.
    Again, THANKS!
    Mike
Page 3 of 3 123
  1. Deluxe Stand and Tormack 1100 and interference with holding fixtures
    By ddixon in forum Tormach Personal CNC Mill
    Last Post: 05-26-2007, 03:15 PM
  2. Lifting fixtures on and off the machine.
    By Smackre in forum Uncategorised MetalWorking Machines
    Last Post: 04-02-2007, 06:18 PM
  3. WorkHolding Fixtures
    By hstanki in forum News Announcements
    Last Post: 03-22-2006, 08:36 PM
  4. Workholding Fixtures
    By hstanki in forum Employment Opportunity
    Last Post: 03-06-2006, 07:35 PM
  5. eroding Wire EDM fixtures
    By Rivet head in forum Waterjet General Topics
    Last Post: 09-30-2005, 01:15 PM
