#furnituremakingmachine
# 1300x2500x200mm effective working area,
# Original Italian HSD9.6KW ATC Air Cooling Spindle, Latest ModelES951, 24000RPM;
#12 pieces Linear Auto tool Changers, below gantry;
#Taiwan DELTA 11KW inverter, top brand;
#Taiwan Syntec 6MB controller with MPG handle wheel;
# Japan YASKAWA 850W servo motor and 1KW drivers, Z axis with brand brake;
#Japan Shimpo reducer, 2 on Y axis, and 1 on X axis
#Whole Vacuum Table, specifically for cabinet working;
#Taiwan PMI Linear guide and rails, 25mm
#Welded machine structure, heavy duty machine body, new design;
#X,Y-helical rack pinion, Z axis with TBI ball screw;
#High soft shield with copper wire to protect against static; electricity, Shanghai Cardiff/German Igus brand;
#Japan Omron limited switch;
# Auto tool sensor;
#1.5L Automatic lubrication system for rails;
#French SCHNERDER switch;
#Chinese JQT 7.5KW Air Vacuum Pump, double stage, two blower;
# 1.5KW double bags dust collector with CE certificate;
#Auto Loading and Unloading table
#Positioning Pop-up Pins, 2 on X axis, 3 on Y axis
#Lamello Function, including 750W Yaskawa servo motor and driver, Lamello saw, and spindle, etc
#220V±10%, 3 phase, 60Hz
