586,051 active members*
3,799 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Deckel / Dialog > I need technical support for Deckel FP50CC please
Results 1 to 6 of 6
    Feb 2008
    15
    Machine Supplier: Deckel
    Machine Type: FP50CC
    Serial Number: 2813-0234
    Machine control: Dialog 11
    Attachment 453124Attachment 453126Attachment 453128Attachment 453130
    The problem is as follow:
    When the system starts, the sequence of starting runs normally and then it finally gives the indicated status in attachments.
    Pushing green control ON button in the operator panel has no effect i.e. (drives not start), the machine then gives no error messages and no alarms as indicated in attachment "monitor1.jpg". But the abnormal behavior is that after the sequence of starting is finished:
    The (READY) led in the NPC card is ON whereas the (RUN) led in this card is OFF as indicated in attachment "Dialog11.jpg"
    The (CNC) led in the NSV card is OFF as indicated in attachment "Dialog11.jpg"
    Please give help to fix this problem
    Nov 2016
    Re: I need technical support for Deckel FP50CC please
    Try https://www.practicalmachinist.com/v...a-abene-mills/. There are very experienced people there.
    Note to Moderator - I hope this post does not contravene forum rules - I'm just trying to assist the OP.
    Bill
    Nov 2016
    That was meant to be practicalmachinist.com/vb/deckel-maho-aciera-abene-mills/ but it came out wrong.
    Bill
    Feb 2008
    15
    Quote Originally Posted by WCD9 View Post
    Try https://www.cnczone.com/vb/deckel-ma...a-abene-mills/. There are very experienced people there.
    Bill
    This website is no longer available
    Feb 2008
    15
    Praise be to Allaah
    My machine has been repairedAttachment 455058Attachment 455058Attachment 455060
    Feb 2008
    15
    The same problem is repeated again
  1. technical support
    By polillo26 in forum SIEMENS -> GENERAL
    Last Post: 12-30-2018, 08:27 AM
  2. vero technical support
    By camaru in forum Surfcam
    Last Post: 12-12-2017, 02:12 PM
  3. CMS Technical Support needed
    By CGR in forum CNC Machining Centers
    Last Post: 02-10-2012, 08:49 PM
  4. Technical Support Representative
    By mgrtorm in forum Employment Opportunity
    Last Post: 12-26-2008, 09:09 PM
  5. Amazing Technical Support
    By DonFrambach in forum Vectric
    Last Post: 12-08-2008, 03:09 PM
