586,103 active members*
3,404 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Importing nc-code/g-code from F-Engrave to Biesseworks
    Nov 2020
    I'm running Biesseworks 3.4. I'm successfully able to import dxf files for 2D vector carvings.
    I would also like to do V-carving and F-engrave seems like a promising software tools for this.
    https://www.scorchworks.com/Fengrave/fengrave.html
    F-engrave generated gcode-files which many of the smaller/cheaper CNC machines seem to read without problem.
    However, I have not been able to import these files into Biesseworks. Biesseworks claim to read "NC" files, but complains about an unknown format when I try to do a "manual import".
    I know gcode comes in many flavors. Has anyone successfully been able to import gcode from F-engrave into Biesseworks?
    Nov 2011
    21
    Re: Importing nc-code/g-code from F-Engrave to Biesseworks
    Biesse has very specific ISO format, if you don't have some postprocessor, you can't do that :-(
    What you could try is to generate NC code from Biesse works editor (programmed some similar panel) and manualy (with Wordpad or similar texteditor) insert the G-code in the right section. But you can't open it in Biesse works editor, only in old Program editor (under CNI WRT), where you can check the functionality.
  1. Importing code
    By D3V3R in forum Mastercam
    Last Post: 08-18-2015, 12:33 AM
  2. BiesseWorks Code viewer
    By James_4716 in forum Uncategorised CAM Discussion
    Last Post: 03-25-2014, 05:10 AM
  3. Importing DXF files into Biesseworks
    By Jmckay in forum Uncategorised CAM Discussion
    Last Post: 03-09-2013, 04:32 AM
  4. Question: Importing spreadsheet data into g-code.
    By TXFred in forum G-Code Programing
    Last Post: 04-02-2011, 05:55 AM
