586,103 active members*
3,579 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Step/dir Servo Drive selection
    Nov 2017
    83
    Hi There,
    I am tryin to pick a servo drive to xyz some servos on an older CNC knee mill I plan to retrofit with a Centroid Acorn control. I was curious if any of you have experience with these drives and would recommend or not recommend them? I am also very open to any other options that you would recommend. The servos are 63Vdc, 3.75 amps, .25hp rated servos. I realize these servos are a little underpowered for the fairly beefy robotool they are on, but I was happy enough with their performance before the old control died, so they should continue to be ok.
    Viper 80
    Viper 80 (replaces V75), ViperServo
    DG4S-08020
    https://www.cnc4pc.com/dg4s-08020-dc-servo-drive.html
    Geckodrive G320X
    https://www.geckodrive.com/g320x-dig...rvo-drive.html
    I admittedly do not know a whole lot about servo drives and am curious if these drives have pros/cons I should know about, or if there is some significantly better alternative.
    The servos have these encoders on them currently.
    https://www.newark.com/broadcom-limi...3c09ef0a240610
    I do have a few CUI AMT113Q-V encoders I picked up from an odd job my work did one time and were going to throw away. I could switch out the original encoders if needed to get better performance too.
    Jan 2008
    1529
    Re: Step/dir Servo Drive selection
    Is budget tight?
    I would probably just get rid of the existing servos and buy new matched AC servos (I'm very happy with my Delta B3 servo - manual is very good).
    I've wasted too many hours screwing around with old DC servo and dumb drives (like the G320x) and was not happy.
    Nov 2017
    83
    Quote Originally Posted by pippin88 View Post
    Is budget tight?
    Yea the budget is a bit tight. I have about $1200, but that has to cover the VFD, Acorn Board, power supply and the servo drives. I would love to go to an AC servo/drive, but that would be another $1000 on top at least. Unless there is such a thing as 3 AC servo with drives for around $600-$700 that can run off of straight 120AC or 240AC without a power supply, I think I will have to stick with the DC servos.
    Sep 2005
    1195
    have you read this thread ... I have gecko dc servo 320x, if you buy now, they are expensive too, not too much different with new ac servo ... ac servo has much better performance ...
    Nov 2017
    83
    Quote Originally Posted by asuratman View Post
    Thats a risky setup right there... more risk than I am willing to take on for $850.
  1. Servo Drive Selection Dugong vs. Gecko drive
    By native34 in forum Servo Motors / Drives
    Last Post: 02-06-2015, 04:37 AM
  2. AC Servo motor/drive selection
    By ravngr in forum Servo Motors / Drives
    Last Post: 09-03-2014, 11:19 PM
  3. Servo Drive Selection
    By lostinspace2009 in forum Servo Motors / Drives
    Last Post: 09-04-2009, 11:31 PM
  4. AC servo Step Direction drive
    By professor in forum Servo Motors / Drives
    Last Post: 11-10-2007, 05:07 PM
  5. Cheap 0 Clifton and servo drive selection (advice needed)
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 04-14-2004, 04:21 PM
