586,116 active members*
3,442 visitors online*
    Jun 2020
    16
    Unhappy CNC Pilot 4290 load errors
    Good day everyone
    We bought Gildemeister CTX 400 with Heidenhain CNC Pilot 4290
    There is issue with machine start
    I will describe chronology:
    1. When we turn on machine, windows 98 show some errors after "blue screen of death" appeared. Unfortunately, operator did not saved firs errors, only BSOD photo we have
    The machine was turned off, we decided to remove the image (clone).
    2. When we found a suitable HDD IDE. We turned on the machine, the machine turnedon without errors. All OK.
    3. We turn off the machine, after we removed the image (ghost) and cloned (acronyx). There were no mistakes.
    The disc worked with a loud noise and we turned it off
    4. Further manipulations were tried with the purchased SSD with IDE controllers and HDD.
    Current HDD has like native 500 mA.
    5. The BIOS sees the disk, the splash screen is loading, the W98 desktop appears and then when the virtual machine starts to load, than a "Error 2 can't load Vdx" pops up
    I press "OK", the loading continues. And the second window flies out
    "Unable to open Vxd x \\ PLX_90xx.vxd <, Error code2". photo attached
    I afraid we have damaged disk image
    I ask for your advice or maby some have disk image?
    Regards Artem
    Attached Thumbnails Attached Thumbnails 9b27494cc694e5c659b47a12208b2e5e-full.jpg   4341e56c714a8affa2313205e817c8b6-full.jpg   6ce6e8c81fa4e3e1913d511176f6ff41-full.jpg
    Jun 2020
    16
    Re: CNC Pilot 4290 load errors
    Problem solved.
    The problem was solved by a colleague, usually he does everything sequentially, but this time he did several operations at once and it all worked.
    The problem went away after changing some protocols in the BIOS, he tried various options and some of the necessary ones matched.
    Resetting settings didn't help.
