586,414 active members*
3,336 visitors online*
    Apr 2006
    1016
    Spindle bearing.....
    Have a question for users that have large ATC Style spindles that have ceramic bearings what do you guys think of them what is the durability and longevity of these bearings what are the pros and cons
    Re: Spindle bearing.....
    Quote Originally Posted by eloid View Post
    Ceramic bearing is much more durable then steel ball bearings, for how long it can be used depends on how often you use the machine and what kind of the jobs.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Apr 2006
    1016
    Quote Originally Posted by cncmakers001 View Post
    Are they quieter... im guess also when using the
    Tool as a probe the tool is insulated from the spindle.
    Has anyone had any bad experiences or issues with them
    15362
    They run smoother and have a much longer life, for probing your probe is independent of anything to do with your spindle, for a tool setter you use one that has a contact switch inside which makes it also independent
    Mactec54
  1. Replies: 35
    Last Post: 03-21-2017, 02:29 PM
  2. Bad Spindle Bearing?
    By skmetal7 in forum Benchtop Machines
    Last Post: 03-21-2012, 07:53 AM
  3. SL-30 spindle bearing
    By CyberLung in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2007, 02:59 AM
  4. spindle bearing?
    By ged in forum Mechanical Calculations/Engineering Design
    Last Post: 08-20-2007, 02:22 AM
  5. Air Bearing Spindle
    By KBW in forum DIY CNC Router Table Machines
    Last Post: 11-11-2003, 03:44 PM
